Need help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-18-2013, 08:16 AM Thread Starter
toad's Avatar
Quoted: 25 Post(s)
Need help
Replacing the injectors on my truck and the very back one by the ac box will not come out. It is hitting the AC box
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #2 of 8 Old 05-18-2013, 09:02 AM Thread Starter
toad's Avatar
Quoted: 25 Post(s)
got it easy chessy
toad is offline
post #3 of 8 Old 05-18-2013, 09:54 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Walking away usually helps
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 8 Old 05-18-2013, 10:18 AM Thread Starter
toad's Avatar
Quoted: 25 Post(s)
walk away, look at the chive, drink a dew, problem solved
toad is offline
post #5 of 8 Old 05-18-2013, 02:10 PM
Chop's Avatar
I've read removing the selenoid from the injector helps ,is that true ?
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #6 of 8 Old 05-18-2013, 03:15 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Yes, removing the solenoid will help. Removing the Vacuum Reservoir that is attached to the A/C box also helps, and if all else fails, remove the A/C box (it's really not that bad ... there is one screw inside the cab under the carpet/mat). Cheers!
Patrick Feeley is offline
post #7 of 8 Old 05-19-2013, 09:09 AM
Just did this on my truck. Once I figured out the A/C box had to come apart it wasn't that big a deal. I will say that once all the bolts are out, take your time about figuring out just how that cover half will come out. Only works one way and once you figure it out, like you said, easy cheesy.
It's too damn hard to try to describe it here. Just have to play with it until it more or less falls out on it's own.
Haulstroker is offline
post #8 of 8 Old 05-19-2013, 09:36 AM Thread Starter
toad's Avatar
Quoted: 25 Post(s)
I removed the vacuum reservoir and had plenty of room.
toad is offline
