Intercooler selection - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-15-2013, 11:13 PM Thread Starter
01Crewcab7.3's Avatar
I found a salvage yard local to me that has several 7.3 and 6.0 trucks. The 7.3 intercoolers are $150 and the 6.0 are $200. My question is basically which one should I get? Its only a $50 difference but I have heard that the 6.0 cooler only makes like a 50* difference if that. Any insight is appreciated.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #2 of 5 Old 05-15-2013, 11:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The 6.0 cooler is obviously more efficient, but you can get the 7.3 one with metal ends and not have to worry in a high boost application of blowing the end off
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 05-16-2013, 09:22 AM
sgt dave's Avatar
Quoted: 3 Post(s)
whats the name of the salvage yard?
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #4 of 5 Old 05-18-2013, 03:29 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I would go with the cheaper 7.3 Cooler with the metal end caps. Some of the later 7.3s have plastic caps like the 6.0 Which blow caps after 40psi
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 5 Old 05-18-2013, 08:08 PM
nohsp4u's Avatar
Is the subway trucks? Do you know if they have 6.0 fans?
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
