Dually spacers - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-14-2013, 02:25 PM Thread Starter
Dually spacers
Hi guys I converted my truck to dually with the conversion kit spacer. Now i'm wondering if it would be safe to add another spacer between the tires. so it would go Tire/spacer/Tire/spacer/axle\spacer\Tire\spacer\Tire.
Rickie Conway is offline
post #2 of 15 Old 05-14-2013, 03:04 PM
ryandamo's Avatar
yea it will be safe if you use a quality spacer, cheap aluminum spacers on a dually hauling weigh will make you wish you spent the extra money real fast. you have to add one when running oversize tires or else they will rub
you should look into getting dually hubs from a junk yard, and then using the spacer you already have in the middle if its not to big, that way you know the inner tire is good at least
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #3 of 15 Old 05-15-2013, 11:04 AM Thread Starter
Yea getting dually hubs would actually be the best root. Will those fit right on to the D50 axle? thanks
post #4 of 15 Old 05-15-2013, 11:12 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Yes they will, direct replacement for the regular 4x4 hub on d50 and d60, I'm selling factory hubs too, need to get rid of them Kause I'm going a different route
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 15 Old 05-16-2013, 03:02 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
If your talking on the rear, which i think you are, you can safely run 2 sets of spacers. I will be on my dually project.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #6 of 15 Old 05-24-2013, 01:55 PM Thread Starter
My buddy told me that for the rear axle I can not do this. That I would have get the full dually axle and that I can't just put the dully hubs on the regular axle. Can anyone confirm this?
post #7 of 15 Old 05-24-2013, 02:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You can put dually hubs on a regular axle, the axles are literally no different than one another, my hubs are for a front axle, as far as rear axles go the dually axle is slightly more narrow than the srw axle is, but basically the same
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 15 Old 05-24-2013, 02:45 PM Thread Starter
o.k if I did put the hubs on I would also have to change the brake drums over to right?
post #9 of 15 Old 05-24-2013, 02:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
No, these are front hubs that I have, they bolt to your stock rotor
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 15 Old 05-24-2013, 04:33 PM Thread Starter
Does anyone have a picture of a hub for the rear axle?
