Tuning issues - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-14-2013, 08:10 AM Thread Starter
95f350powerstroke*'s Avatar
Tuning issues
Hey guys I have tw tunes in my truck. Eco, daily, heavy tow, high idle, street, and extreme. I'm not happy at all with my heavy tow tune. When I'm towing it doesn't want to lock the torque converter up. It leaves it unlocked and runs my trans temp up. Also I have a slightly built tranny. Triple disk, trans go, extra clutches all the good stuff. Should I just look into a new tuner? Thanks guys.
1995 F-350 Reg. 4x4 7.3, TDP chip with TW tunes, gauges, DIY intake 5" turbo back
95f350powerstroke* is offline
post #2 of 13 Old 05-14-2013, 09:08 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
have you contacted the retailer on your tony tunes? also did you mention the fact your have a specialty trans in it?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 05-14-2013, 12:21 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
You have more torque with the TC unlocked. My TW tunes Heavy Tow setting doesn't lock the TC till 62-65 MPH. The tow setting is for down low power cutting fuel above 2200-2500 RPM. It's for grunt not freeway cruising. I tow kinda heavy and have not needed the setting unless I'm on a loooooooong hill.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 13 Old 05-14-2013, 08:11 PM Thread Starter
So would the tow tune be better suited for me? Also I have 3.73 gears and yes I did mention that about the trans.
post #5 of 13 Old 05-14-2013, 08:29 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Did you re gear it?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 13 Old 05-14-2013, 08:59 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
The TW tune should lock the converter in third (instead of fourth) when you push the OD off button. Does this happen?
Matt
'97
-Stage II trans.
BigFuel is offline
post #7 of 13 Old 05-14-2013, 09:03 PM Thread Starter
No I didn't. And I haven't tried that. I figured it should do it's own thing
post #8 of 13 Old 05-14-2013, 09:17 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
The reason Kris asks is that 3.73's are not avalible from Ford in the Diesel. More likely you have 3.55's if you are having difficulty with these tows.
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 13 Old 05-14-2013, 09:27 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
On the door jam what is printed on the sticker where it says axle cd. Should be a letter and a number. Now someone still could have changed it after the fact.
Matt
'97
-Stage II trans.
BigFuel is offline
post #10 of 13 Old 05-14-2013, 10:27 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
A letter denotes limited slip
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
