Same Boost After TW Chip??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-29-2013, 01:40 PM Thread Starter
My truck would max out at 17psi of boost with Exhaust and Intake. But i was alittle disapointed with my boost numbers after my TW Chip. I was still only making 17 pounds. I have checked for up-pipe leaks and cant see anything. Any help would be greatly appreciated.
Love the Forum BTW!
1995(single cab) F350 XLT 4x4, Factory D60, 4:10's, 20x12 Fuel Hostages, 33x12.50x20 Toyo Open Country M/T, 5" Diamond Eye(straight), 6637 Intake, Pillar gauges, Fully built E4OD, Beans E-Fuel, 360 turbo rebuild with WW2, and 1.0 quick spool exhaust housing.
Tillman21 is offline
post #2 of 11 Old 04-29-2013, 03:18 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
does it feel any different? maybe the gauge is off and what tunes if any where you running before?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 04-29-2013, 04:38 PM Thread Starter
I can definately tell a difference, especially in Extreme. But I has all stock tuning before this. It runs good, just seems low on boost. Only thing I've noticed is the turbo wheel seems to be dusted pretty good, could this cause this issue?
post #4 of 11 Old 04-29-2013, 07:31 PM
OL' OutLaw's Avatar
yes it will ...time for a D66
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #5 of 11 Old 04-29-2013, 10:11 PM
jjones96's Avatar
D66 with stock injectors?
Is ur boost gauge tied into ur map line if so that could be giving u an incorrect reading
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #6 of 11 Old 04-29-2013, 11:32 PM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
Have you pressurized the system and checked for leaks? There are only a few spots it could leak on an OBS, but any boost leak at all will be noticeable.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #7 of 11 Old 04-30-2013, 05:11 AM Thread Starter
A D-66 is down the road. But for the time being, i think a turbo rebuild and a Wicked Wheel 2 is in order
My boost gauge is tapped into the intake spyder, so it should be good.
How would i go about pressurizing the system to check for leaks?
post #8 of 11 Old 04-30-2013, 08:58 AM
jeremiahmercier's Avatar
Did you seal the boost guage sensor where you tapped the Y?
-1996 f250 4x4, ZF5, ECLB, MM manual hubs, Firestone ride-rite air bags, Fuel tank vent mod, Live tuned Dp-Tuner, Tymay intake, 3"dp, FF stage 1-160cc/0, HPOP-X, CCV mod, t500 , SB clutch, D66, BD-exhaust brake, Beans Fuel system, and hypermax intercooler.
-2002 F250 4x4, auto, ECLB, CAI, CCV mod, Live Tuned Dp-Tuner, air heater delete, 4"dp
jeremiahmercier is offline
post #9 of 11 Old 04-30-2013, 09:39 AM
OL' OutLaw's Avatar
you might want to check this out before you spend any $$$ on a stock rebuild..... :
This guy was talking about rebuilding your stock turbo with a 66mm intake side, a Billet Wheel, and using the 360 degree thrust for around $600.00 bux...hellova deal.
Anyone interested in a DYI Billet 66mm OBS-E99 Kit - PowerStrokeArmy
post #10 of 11 Old 04-30-2013, 10:33 AM
Quoted: 45 Post(s)
Just Google the term boost leak tester. There are many write-ups on how to make one. It is cheap and easy.
DP-Tuner
Like us on
Justin Bochmann
Tags
boost , tw chip
