3 inch plenums - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-28-2013, 06:10 PM Thread Starter
OBS Strokin's Avatar
3 inch plenums
Hey everyone I have bought the Banks techni cooler for my truck and getting ready to install it. I know the intercooler comes with their own custom intake to the motor instead of the stock y pipe. Now would in benefit me to go ahead and buy the 3inch intake plenums? I know that the intercooler intake they sent will probably not work so I might be able to trade it out for a 99 or later banks intake? Also, I am starting to put the money into the truck and plan on loads more mods so please any suggestion be appreciated?
96 7.3 F350, 4x4, 5 speed, 6 inch skyjacker lift, 35 12.50 M/T Baja Atz, custom TW 6 pos, Banks Intercooler, BDP experimental fuel system, banks double shot water meth, Chromoly Push Rods, Swamps IDM Mod, 2nd Gen Wicked Wheel, Stage II AFE cold air intake, Down Piped 5 inch Diamond Eye exhaust, Gauges, ladder bars, upgrades drives lines yokes, on board air system, triple trumpet train horns, smoked head light and taillight housings, and 55watt HID kit!!
OBS Strokin is offline
post #2 of 6 Old 04-28-2013, 06:57 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
The 99 Banks intake would not work due to the difference in turbo flanges between OBS and SD turbos. I don't know how beneficial it would be, but you might be able to get transition boots that go from 2" to 3". I also don't know how well an early 99 SD intake would line up with the Banks piping (the early 99 has 2-3/8" runners). Cheers!
Patrick Feeley is offline
post #3 of 6 Old 04-29-2013, 01:17 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
the E99 and banks intake are also very different. if you have banks piping you need the banks spyder, if you have the banks spyder you need the banks piping. 3" plenums would be nice, but not necessary
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 6 Old 04-29-2013, 02:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
3" plenims wont fit without going to e fuel anyway, you have to remove the fuel bowl and use an sd top end or just e fuel it all up and no sd fuel bowl
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 6 Old 04-30-2013, 08:44 AM
OL' OutLaw's Avatar
and when you got all done with all that, it wouldn't run a bit better unless you had Stage III's in it anyhow....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #6 of 6 Old 05-06-2013, 11:05 AM Thread Starter
Thanks guys!!! I am on my way to Stage III's FFD injectors, BDP fuel system and I was just wanting to do the change now instead of later, but I guess I can deal with that down the road!!
