f350 fuel economy - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-26-2013, 08:58 PM Thread Starter
spartan-alteran's Avatar
f350 fuel economy
hi I wana get my 7.3L to get as much economy and help out the engine last any suggestion for a 2000$ budget ?? I got pic of the truck just check out my profile page and you suld see um
spartan-alteran is offline
post #2 of 11 Old 04-27-2013, 06:15 AM
Redlazer's Avatar
There is a few things you can do is straight pipe oem exhaust. When u get new tires go up in size but no more than 2 tire sizes example stock is 265x75r16 you can go 285x75r16. Also up grade to a high flow air filter. A better flowing turbo upgrade. With only 2k you can't up grade injectors. But these things would help you increase your fuel economy. One other thing is I have been reading is propane injection cab increase fuel economy a good amount.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #3 of 11 Old 04-27-2013, 07:31 AM Thread Starter
tiers I was debating between 33" - 35" and watt about a cold air intake ? and the exhaust well I was thinking of getting a 4" down pipe and a 4" exhaust to help the engine, would you have any suggestion's on this ?
post #4 of 11 Old 04-27-2013, 08:15 AM
Redlazer's Avatar
The 285x75r16 tires are 33s. I would not go any higher if you want fuel economy. The exhaust you said would be good, but I suggested straight pipeing the oem exhaust to save money. Both would would work great. Anytime you save money on something more parts you can get.
CAROLINA GRAY BOY
Redlazer is offline
post #5 of 11 Old 04-27-2013, 12:11 PM
01Crewcab7.3's Avatar
You cannot fit a 4" downpipe on these trucks without serious modification to the firewall.
Get a 6637 filter and do the DIY intake. Cheapest and best intake for these trucks.
Do a 3" downpipe with a 4" straight pipe exhaust.
Get a set of gauges pyro, Trans temp, and boost.
Lastly get a chip from someone like tony wild man or bill @ php. Should wake the truck up quite a bit and help with some fuel economy.
As for the tires. If you have 4.10 gearing then going to a 35" tire will help fuel economy on the freeway only. It will hurt in town economy.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #6 of 11 Old 04-27-2013, 01:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Intake, down pipe, straight pipe, skinny tires, and custom tunes, I achieve 15+ mpg in my CClb dually mixed on stock truck with intake only
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 11 Old 04-28-2013, 07:55 AM Thread Starter
k time to start looking for the parts =) thanks guys
post #8 of 11 Old 04-28-2013, 09:04 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You can find a full exhaust cheap on amazon, or try the vendors here, and they have no problems giving you exactly what you need and give great advice
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 11 Old 04-28-2013, 09:02 PM Thread Starter
well one of my frends is ready to sell me hise chip for 200$ but we can't seam to find the port to plug it in, and time to look on amazon =P
post #10 of 11 Old 04-28-2013, 10:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Better make sure his chip is for the same truck, pull the e brake to see the PCM code, pull PCM from under good to install chip in it
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
