TW chip stuck on one tune - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-23-2013, 11:31 AM Thread Starter
metallitera's Avatar
I dont change tunes very often, so im not sure how long its been stuck. If i mess with the knob sometimes it will start working.....well i have having throttle pedal problems intermittently as well, so I thought they were related. After pulling the codes and replacing throttle and cam positions sensors, the chip is still stuck in tune #1. I removed the chip, ran the truck, re installed the chip, and it worked fine for a cpl days then no more changin tunes.
Any suggestions?
-ReD
Fire Lieutenant/Paramedic, Tinkerer
1990 Jeep Wrangler YJ
metallitera is offline
post #2 of 4 Old 04-23-2013, 11:34 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
send it back for a reburn? life time free rite?, make sure the chip is properly seated, has it been working a little loose?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 04-23-2013, 11:50 AM Thread Starter
That was my first thought. chip was seated well when i took it out, tape was still in place. re seated and re-taped when i put it back in.
-ReD
post #4 of 4 Old 04-23-2013, 02:28 PM
OL' OutLaw's Avatar
you might try re-cleaning the PCm....use a small amount of your wife's (girlfriend's), fingernail acetone......might have a bit of crud still on it.... ?
or you could unplug the knob from the chip, give the knob internals a squirt of Electrical Contact Cleaner, work it all one way, and then back 40-50 times, squirting it once inna while and clean it,
the make sure it's DRY and try plugging it back in then....
you can also borrow one (knob and cable) from your buddy and unplug yours from the chip and plug his in, if it works then, it's your knob switch....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
