just got my banks housing - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-15-2008, 09:41 AM Thread Starter
I just got my banks turbo housing today, and it came with no instructions what so ever. Ive helped put an ATS housing on a friends truck before and I figure its the same concept. It looks likes its just 4 bolts on the flange and thats it. It came with no new bolts, but it did come with 2 different sized O rings. Has anyone installed one of these or know how to?
96 F250 PSD, 4in. MBRP w/ muffler delete, DIY intake, TW 6 pos, Banks turbine housing, 3in. suspension lift, 33'' Nitto Terra Grapplers.:burnout
96firebird is offline
post #2 of 7 Old 02-15-2008, 09:58 AM
jcmagone's Avatar
I put a 1.0 housing on my truck and I will tell you right now it is not a good time. With mine I had to pull the complete turbo and pedestal to be able to seperate the housing from the rest of the turbo. You will have to remove any of your intake hoses and the down pipe will have to be disconnected from the turbo. Then there is four bolts that hold the pedestal to the motor and several more that hold the housing to the Up pipes. You will learn to hate the rear bolt on the drivers side cause the actuator for the EBPV is in the way. Once you get the pedestal and the turbo pulled from the truck then you will have to remove the EBPV housing from the trubo and then you can unbolt and seperate the housing from the rest of the turbo. I would get some good penetrating oil on the bolts and housing right away. Everything will go back in just the reverse order. Also the two O rings go between the pedestal and the top of the motor. I am sure I am missing something but that is the general idea. Good Luck.
95' F-350 PSD, CC, 4x4, LB, srw, auto w/4:10s, Stage 1 injectors (RDS), 17* HPOP (mod by Joey at TE), Wildman Chip, EBPV gone, Down Pipe, Stainless Monster Exhaust, AFE intake, Techni-Cooler, 120V IDM, Sky 3" RSK, 2" add-a-leaf on rear, Bilsteins, Onboard Air, Front and Rear Bags, Weld Cheyenne 8's, BFG Mud35/12.50 on 18's
Last edited by jcmagone; 02-15-2008 at 10:02 AM. Reason: Poor spelling and I am sure there is more.
jcmagone is offline
post #3 of 7 Old 02-15-2008, 10:04 AM Thread Starter
Yea I didn't figure it would be a fun job, but I'm gonna hit it with some PB blaster and let that soak for a day and hopefully that'll help loosen them bolts up.
post #4 of 7 Old 02-15-2008, 07:31 PM
PSMstroker's Avatar
how nice is that 1.0 housing on your truck jcmagone. hows the truck run with it on it now, as in power gain and trubo respones, and pull.
96 power stroke
extended cab long bed
4 wheel drive
4" Diamond Eye Performance exhaust system
Auto Meter sport comp Pyro, tranny, and boots
Edge EZ
S&B intake
FPR shim
Banks transcomand
Banks ottamind tuner
150 DBA 150psi train horns
5 gallon air tank and Viair 480c compressor
2.5" tuff country lift kit
285/75/16 goodyear wrangler duratracs
E4OD automatic that is fresh.
PSMstroker is offline
post #5 of 7 Old 02-18-2008, 05:37 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
This may help. Once you get the turbo off, just remove the turbine housing and replace it with the Banks housing.
http://www.powerstroke.org/forum/7-3...tion-tips.html
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #6 of 7 Old 02-18-2008, 06:24 AM Thread Starter
Thanks alot those instructions are very detailed and are gonna make my life a whole lot easier, i hope. What kind of housing do you have on yours?
post #7 of 7 Old 02-18-2008, 10:24 AM
jcmagone's Avatar
The nicest thing about the 1.0 housing is a good chunk of the turbo lag is gone. The turbo spools up and builds boost sooner. Banks claim they will actually lower egts but I'm not sure about that.
jcmagone is offline
