Scangauge II users - What all can you read? - Ford Powerstroke Diesel Forum
post #1 of 30 Old 04-21-2013, 12:53 PM Thread Starter
Boise Outlaw's Avatar
So far my scangauge wont give me any important readouts, just the stuff that is already displayed such as volts, mph, tach. For temperature values it gives me -40 degrees, and it doesnt show anything for Horsepower, Torque, Gear Ratio, any of the things a person might actually want to display.
First off it didnt automatically recognize my truck, so i had to force the PWM. Was this common with everyone else?
Anyways what all values are you guys able to display? did you have to manually enter the stuff via the xgauge or were they always available to you?
97 OBS F250 Ext Cab Long Bed 4x4 ZF Swapped
VO conversion, TS 6 Position Chip, E Fuel, 6637 Filter, EBPV delete + PCV Reroute, Diamond Eyes 3" Downpipe
Boise Outlaw is offline
post #2 of 30 Old 04-21-2013, 06:11 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Afaik scan gauge II don't work with the obs, 99+ only
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 30 Old 04-21-2013, 07:26 PM
The Maddawg
maddawg89's Avatar
Quoted: 275 Post(s)
Feedback Score: 3 reviews
Even then for most 99-03 trucks I dont think things like egts and boost and temps would be displayed as there isnt the right sensors attached. Is this correct? iirc when I was looking at a Bullydog tuner with the big screen (forget which model it was) the dealer was telling me I couldnt moniter all of that in my truck with it b/c the sensors didnt exist.
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #4 of 30 Old 04-22-2013, 11:32 AM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
The only two important PID's the PCM does not monitor on a 7.3L(OBS and SD), are EGT and fuel pressure. The PCM does monitor boost, EOT, trans temp, ICP, IPR, etc.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 30 Old 04-22-2013, 05:12 PM
The Maddawg
maddawg89's Avatar
Quoted: 275 Post(s)
Awesome. Thanks Justin!
Bully Dog intake
post #6 of 30 Old 04-23-2013, 01:02 AM
Quoted: 45 Post(s)
No problem. Glad I could clear that up for you.
DP-Tuner
Like us on
Justin Bochmann
post #7 of 30 Old 04-25-2013, 06:57 AM Thread Starter
I assume i'll have to manually enter the codes for those then? I found a page on the scangauge site with a bunch of special xgauge codes for fords. I guess i'll have to punch em in and get her figured out.
post #8 of 30 Old 04-25-2013, 12:12 PM
Quoted: 45 Post(s)
I am not sure how the Scan Gauge works, but if they do not show up automatically, then I am sure you will have to type in the code for them.
DP-Tuner
Like us on
Justin Bochmann
post #9 of 30 Old 04-25-2013, 01:13 PM
Quoted: 43 Post(s)
Unless they have a recent update, those are for Superduty PSDs. I tried a couple; I believe I tried EOT. No luck.
Seems to me someone _could_ find/create the right XGauge codes to get things like EOT, ICP, pedal position, etc. I'm quite sure the "formulas" for these are different for the OBS than for the SD, and I'm guessing no one has bothered to determine what those formulas/codes should be.
madpogue is offline
post #10 of 30 Old 04-28-2013, 11:26 AM Thread Starter
alright so i've gone and updated all of the xgauge commands in my scangauge II and am still not able to get any new readings.
I went through all of the xgauges available. Updated the ones to reflect the codes on this page here and added the additional codes that were not present already. I can still only get readings for Speed, Voltage, and RPM. I have yet to mess around with the whole economy thing.
What other sensors does the OBS read? I know it has a fuel pressure sensor on the FPR (i removed this when i switched to an aeromotive). And I had heard there is a transmission temp sensor in the E40D. Also for some reason my scangauge isnt reading my coolant temp and reads as -40 degrees, but the factory gauge is working.
I was really hoping this thing would monitor useful stuff, but i feel like it is just going to be a code reader until i have another newer vehicle to put it in.
