T3 to t4 upgrade. Difficulties? - Ford Powerstroke Diesel Forum
post #1 of 25 Old 04-13-2013, 04:30 PM Thread Starter
Jerzyperson's Avatar
Thinking about upgrading to a t4 billet S300 turbo. And the T4 pedastal and up pipes. A: would this turbo and system from swamps work on my OBS. B: how difficult would it be to do myself? I plan on going through swamps on many things. And found this setup was cheaper then a hypermax T4. Or should I just put the H2E setup on? What modding needs done then?
Jerzyperson is offline
post #2 of 25 Old 04-13-2013, 06:36 PM Thread Starter
Needs to back swamps 200/200% injectors
post #3 of 25 Old 04-14-2013, 08:16 AM Thread Starter
No input into this?
post #4 of 25 Old 04-14-2013, 09:34 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
The hypermax is a T4i set up. Different then a T4. Is swamps selling a kit made by irate diesel?
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 25 Old 04-14-2013, 10:26 AM Thread Starter
i don't know. Its the 71mm billet S300 T4 and I was gunna get the T4 pedastal and turbo up pipes. If I went with the H2E would I have to do up pipes? I know swamps has the H2E turbo and mounting kit...
post #6 of 25 Old 04-14-2013, 10:41 AM Thread Starter
Ok I like swamps T4i turbo. The hypermax with mounting kit. What difficulties might I run into swapping from stock turbo?
And will this turbo back 200/200% injectors?
post #7 of 25 Old 04-14-2013, 05:17 PM
ol_Blue97's Avatar
No matter whos kit u buy it will be replacing the up-pipes.a t4 kit lets u install borgwarner and garrett turbos. A t4i lets u use hypermax (or a modded hypermax) and bell turbos such as a qssb or a gqssb, ect..
FRANK THE TANK
post #8 of 25 Old 04-14-2013, 08:36 PM Thread Starter
So in your opinion? Billet S300 T4 or H2E? Which will hive me best boost and performance? And will the S300 work with a hypermax intercooler?
post #9 of 25 Old 04-14-2013, 08:51 PM Thread Starter
Ok. Different question... best T4 turbo? If I did up pipes. What should I put up top? For 200/200% swamps. Custom swamps chip. Hypermax intercooler. Stage 2 BTS Tranny and 17* HPOP?
post #10 of 25 Old 04-15-2013, 05:02 AM
Countryboy_7.3's Avatar
I talked to Jake at Irate and he said for my size of injectors(210/100), the s468 will be quick spooling and low smoke. He said with that combo I would be in the 500-530hp range. Give Jake a call.
-2002 f350 7.3L diesel
-20x12 fuel hostages, 325/50r20 atz's
-05 grille, bull bar, recon lights
-BTS
-Garrett 38r
-5inch straight pipe to 7inch fte black stack
-Full force 210/100
-Adrenaline hpop
-Hydra chip from PHP
Countryboy_7.3 is offline
