1996 OBS Build Ideas Help! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-13-2013, 01:54 PM Thread Starter
Well it's finally about time to start dumping money into my 1996 ECSB 2WD powerstroke.
I'm probably gunna have about 3-5 grand to spend..
This is my first diesel truck and I just wanted some ideas and opinions on how I should build her up...
Truck is all stock at the moment.
Trans has no been touched I believe but is still strong.
This is what I was thinking of doing...
AFE Intake.
Stage 1 or 2 injectors (need help here)
66m turbo(also need some ideas/help here)
4in straight pipe exhaust or stack.
TS chip with custom tunes.
Also need info if I should build the trans or not..
The truck is a daily driver, and I never tow anything..
Zdubba994 is offline
post #2 of 2 Old 04-14-2013, 10:40 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Look into a vb and tc for the trans, beans d66 turbo, stage 2's and a bigger hpop, as well as e fuel
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
Tags
help wanted , new guy , obs powerstroke
