hybrid injectors, what mods? - Ford Powerstroke Diesel Forum
post #1 of 67 Old 04-10-2013, 08:52 PM Thread Starter
I want to put some new injectors in my truck, i was thinking like 238/80 or something like that. I know a upgraded hpop, but what else HAS to be done. Money doesnt grow on trees unfortunately haha I have a five speed with a luk solid flywheel clutch in it, it is fairly new. I would just have them detuned until i could afford the other mods. Thanks.
95 f250 powerstroke, zf5 with solid flywheel conversion, 3 inch downpipe to four inch diamond eye stainless steel exhaust, riffraff 6637 intake, pyro and boost gauges, and more to come
_95stroke is offline
post #2 of 67 Old 04-10-2013, 09:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
big air, big fuel, and you already guessed big oil
your going to need to do an e fuel set up, and your going to need a bigger turbo
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 67 Old 04-10-2013, 10:58 PM
Justin@DP-Tuner's Avatar
Quoted: 61 Post(s)
238/100 are stage 3's and are very common. The quote below states what you will need to run these efficiently.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 67 Old 04-11-2013, 06:57 AM Thread Starter
Ok. Ive been reading about e fuel a lot lately, id like to do the diy one cause its cheaper, but have no clue where to start? And also on the turbo, would the stocker be ok for a while if the sticks were detuned? Or would it tear it apart? Also for the hpop i was thinking the t500.
post #5 of 67 Old 04-11-2013, 07:53 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The turbo needs to be inspected at least, hybrids don't really detune like stage 1 or 2's tho, but they do a little, try a d66 or at bare minimum a ww2 in there, and start with a fuel pump and filter bases, then get some hose and proper fittings to run it all
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 67 Old 04-11-2013, 08:59 AM
Full A-Team Member
Fordman247365's Avatar
Might as well plan on and intercooler also.
Intercooler $600
E fuel $600
T500 $450
D66 $1300 w/WW2 (actually not enough turbo but it will get it by)
Injectors $1600
New clutch $500
Basic list, find that $$ tree....
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #7 of 67 Old 04-11-2013, 09:03 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
And a sharp axe, this won't be cheap
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 67 Old 04-11-2013, 09:05 AM
Full A-Team Member
But yes, it can be done a piece at a time, so buy the right parts the first time, once
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #9 of 67 Old 04-11-2013, 05:00 PM Thread Starter
Ok. So injectors def will be the last thing to put in then. I will prob shoot for e fuel first, then t500, turbo, then intercooler, and a clutch. Thats a lot haha, more than i was wanting haha. But a piece at a time. I was wanting hybrids cause ive heard they have great tunability, and loads of power lol. Will everything engine wise hold up? It only has a 190k on it.
post #10 of 67 Old 04-11-2013, 05:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
shane evidently fears no mod at 461k, but your should be fine, I keep adding and im at 300k each
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
