MBRP 4" Exhaust - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-09-2013, 03:12 PM Thread Starter
MBRP 4" Exhaust
I just had the 4" MBRP installed with muffler delete and down pipe. Sounds great with deep throaty roar, and turbo whistle even at the slightest push on the "go" pedal. Turbo is definitely more responsive, the whole truck seems to perform better. I had the stock exhaust with muffler and cat. previously. No rubbing or noise from exhaust hitting the firewall. The installers are diesel guru's, so they knew what they were doing.
'97 XLT F-350 Crew Cab LB, 240,000 miles, 20x10 MB Rocker Rims, with TOYO 35x12.50x20, tool box, Swamps TS tuner, MBRP exhaust S&B Intake, Auto Meter gauges.
xjaddiction is offline
post #2 of 2 Old 04-09-2013, 07:46 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Glad your enjoying it, I have a 5" rbp tip as well on mine, can't wait to try a stack again
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
