97 stock replacement fuel tanks. - Ford Powerstroke Diesel Forum
post #1 of 39 Old 04-04-2013, 09:47 PM Thread Starter
Jerzyperson's Avatar
Is there a company that makes OEM replacement tanks for like my 97 powerstroke? Have a cracked rear tank and need to replace. Curious if there's any company that makes bigger or sturdier tanks? I'm not having any luck finding new replacements. And had bad luck buying used in the past.
Jerzyperson is offline
post #2 of 39 Old 04-04-2013, 11:20 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I heard napa or autozone make them, larger capacity too, or you could go new bronco replacement tank
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 39 Old 04-04-2013, 11:36 PM
boynamedsue's Avatar
summit racing for $ 91.00 on the rear tank. got the same problem with my 97' placing my order tomorrow. hint: take the bed off makes the change out MUCH easier.
Sent from AutoGuide.com App
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
boynamedsue is offline
post #4 of 39 Old 04-05-2013, 12:01 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
But you have to take the bed off lol, I've dropped rear tanks bed on, gotta find the perfect angle around the hitch lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 39 Old 04-05-2013, 05:05 AM
Ha Ha Yes, yes you gotta take the bed off. Not so bad, the local Ford dealership does this when they swap out the old tanks. Apparently Ford doesn't make a truck that doesn't leak fuel at some point in its life span. Im building and installing a flat bed anyway so off goes the old bed and in with two new tanks, pinion bearing and seal and new exhaust, then flatbed. Just ordered my rear tank from Summit Racing was 118.00 with shipping, handling and tax. It will be here tomorrow.
post #6 of 39 Old 04-05-2013, 06:54 AM
erics diesel's Avatar
look on bronco graveyard for tanks you can get plastic tanks and not have to worry aqbout them leaking again
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #7 of 39 Old 04-05-2013, 08:02 AM Thread Starter
I dropped mine bed on. Thought i had some loose connections. Nothing is a harder kick in the crotch the dropping the tank only to find the problem clear as day on the bottom lol
post #8 of 39 Old 04-05-2013, 08:08 AM Thread Starter
Summit has 2 19 gallon replacement tanks. Both 19 gallon tanks. Imma be ordering mine soon.
post #9 of 39 Old 04-05-2013, 10:57 AM
If I remember right, the dealership wanted around 500.00 per tank. What a rip-off!
post #10 of 39 Old 04-05-2013, 11:17 AM Thread Starter
DANG!!!
