diamond eye dp question - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-03-2013, 10:18 PM Thread Starter
hey guys I already have 4in straight pipe form the stock dp back. Do I need both pieces of the diamond eye kit or can I jsut run the first one and fill in any gap with more 4in pipe? also if I can does anyone know what diam the pipe is where the 1st and 2nd section connect?
1996 F-250 crew cab 5 speed
diy intake 4in dp back exhaust
gauges and ts 6 chip
ClutchKick512 is offline
post #2 of 15 Old 04-04-2013, 09:21 AM
SoCalPwrStrk's Avatar
You will need both pieces of the 2 piece down pipe, as the 2nd piece has the rotating joint to connect to your existing 4". In the picture, the DP is on the right and it is 3"
"Big Truck" 1997 F-350 CC DRW 4x2 Cali model
Diamond Eye 3" dp to 5" straight pipe, DIY 6637 intake, Pillar gauges, 6.0 trans cooler, Intercooled, TS 6 pos. chip with TW Tunes, 1.0 Housing, Barder Billet Wheel, EBPV Delete
"Baby Truck" 1999 Ranger EC 5 speed 3.slow
Camburg Long Travel, Billit upper arms, Fox dual rate coilovers and double bypass in front, Deaver race pack w/ fox double bypass in rear, fiberglass fenders, 16x8 American Racing Mohave Wheels
SoCalPwrStrk is offline
post #3 of 15 Old 04-04-2013, 10:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Like said, 4" straight won't fit up there need big firewall mods to fit it, you will need both 3" sections of the downpipe
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 15 Old 04-04-2013, 10:34 AM
jake_duet's Avatar
I got the 4" dp to fit up there.. No trimming or anything. Its a ***** to take out the 3.5" cause of all the heat wrap on it, but once you can get that pipe out, you can slide the 4" right up.. Takes a little wiggling and pushing but it pops right up in there.
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
post #5 of 15 Old 04-04-2013, 11:03 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
In an obs? I had a hard time fitting a 3" dp in there bud most of us actually did
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 15 Old 04-04-2013, 12:51 PM Thread Starter
I dont have that joint anymore I cut it jsut before that and welded the 4in on from there. I just wasnt sure if the first section brings it down under the truck or stops like half way ddown the trans. I could make a 3 in section to go from the first section to the 4in that I have if it comes to the bottom of the trans. Just trying to save some money if I can.
post #7 of 15 Old 04-04-2013, 01:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It stops about half way, about at the pinch weld
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 15 Old 04-04-2013, 02:12 PM
Do they even sell just the upper piece by itself?
post #9 of 15 Old 04-04-2013, 02:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Seen one for sale used once
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 15 Old 04-04-2013, 02:47 PM
superduty4x4's Avatar
Somebody went to a T4 mount most likely, which uses a different upper section of the down pipe.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
