Gauges - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-31-2013, 08:37 PM Thread Starter
PhilMac's Avatar
Gauges
Hello,
I am new to the site but not Powerstrokes. I've got a 97 F-350 7.3 zf5 with 360,000 miles on. It still runs like a champ but could use a little "massaging". I am planning on ordering a DP T5 in the next week or two. I will also be adding gauges. Obviously I plan to install a egt and boost but I cant decide on the third (plan to get a 3 pod apillar mount). I know opinions vary but I am looking for the best gauge for number 3. I was thinking of a water temp since the factory gauge doesnt tell you much but I didnt know if that was a bit reduntant given that I will be getting a egt. I was also considering hpop or fuel pressure gauges for diagnostic purposes in the event I have a problem.
Current mods are 6637 intake and straight pipe exhaust. Other than the above the next mods will be DIY intercooler and 3" downpipe.
Any help would be great!
PhilMac is offline
post #2 of 12 Old 04-01-2013, 02:19 AM
Justin@DP-Tuner's Avatar
Quoted: 50 Post(s)
A good third gauge for you would be fuel pressure. The HPOP gauge is near worthless if you cannot watch IPR.
Have you checked out our Infinity monitor/programmer yet? If not, go HERE. It will monitor everything the PCM sees and you can add additional inputs/sensors for stuff the PCM does not see. This would include EGT and fuel pressure. It will also run diagnostic tests as well.
Let me know if you have any questions.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 12 Old 04-01-2013, 09:09 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Get a scan gauge
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 12 Old 04-01-2013, 05:37 PM
jjones96's Avatar
Or if its an auto trans temp is nice as well
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #5 of 12 Old 04-01-2013, 05:46 PM
481-SCO's Avatar
I have the fuel pressure gauge as my 3rd
Name is Allen
97 F350 Crew Cab 7.3 5 speed 6 position TS chip,Glow Shift gauges Boost,fuel pressure, and EGT has a flat bed.
Keep Oklahoma Powerstrokes alive
481-SCO is offline
post #6 of 12 Old 04-03-2013, 07:36 AM Thread Starter
PhilMac's Avatar
Thanks for the help guys. I ended up ordering the DP F5 last night and stuck with pyro and boost and opted for the gauge pod switch from DP to stick in the third hole. Looking forward to trying it out!
PhilMac is offline
post #7 of 12 Old 04-03-2013, 07:40 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
beat me to it with the switch....you'll love, just beware more power leads to bad things....aka wantng more
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #8 of 12 Old 04-03-2013, 01:33 PM
Quoted: 50 Post(s)
You will love that setup. It looks very clean as well
DP-Tuner
Like us on
Justin Bochmann
post #9 of 12 Old 05-14-2013, 07:34 AM
IU 89's Avatar
PhilMac - I am looking at similar mods, exhaust, chip and gauges. I have a 3" DP already, will add a 4" exhaust and Tunes. If at all possible could you post a pic of the gauges when installed? I will have to make the same decision in the near future. Thank you.
IU 89 is offline
post #10 of 12 Old 05-14-2013, 09:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
honestly if you got gauges, and the gauge mount for your chip, and dp tunes, you should have just gotten the infinity, cost a little more, but does everything you bought gauges for, just need the adaptor for egt
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
