Chip - Ford Powerstroke Diesel Forum
post #1 of 24 Old 03-30-2013, 11:37 PM Thread Starter
97Strokin''s Avatar
Chip
So I have a ts 6 position in my 97 but would like to leave my edge in for gauges. I tried leaving it in there on stock but it won't read the vin like it can't connect with my pcm. Is it possible to do this out do I have to put a pod in?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
97Strokin' is offline
post #2 of 24 Old 03-31-2013, 12:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Which edge is it?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 24 Old 03-31-2013, 05:58 AM Thread Starter
97Strokin''s Avatar
Cs
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #4 of 24 Old 04-01-2013, 10:12 AM
Dirt rider1's Avatar
I'm really wantin to buy a ts 6position with 140hp. How much power/smoke is put out at 140?? Be kind to me bout askin bout smoke.... I'm just curious.
Do u have a video of the truck at 140??
Jordan
(dirt rider1)
1997 7.3 Powerstroke 2wd auto
Mods:
-Muffler cut off
-Cat. converter gutted and gone
-Diamond Eye 3" downpipe
-MBRP 4" exhaust (runs in front of rear wheel)
-Dodge Towing mirrors
-AFE high flow intake
-Real Tree seat covers
-Real Tree floor mats
-blacked-out headlights
-cab lights
-6 by 8' flatbed
-KC lights
-silencer ring removed
-17ton anchor shackle
Dirt rider1 is offline
post #5 of 24 Old 04-01-2013, 10:26 AM Thread Starter
97Strokin''s Avatar
Not yet 140 will set you back in your seat and leave a ribbon as long as your in the throttle but brings up your egts so get a pyro
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #6 of 24 Old 04-01-2013, 10:36 AM
JBRIXEN's Avatar
on the 140 setting, you will really see about 60-70hp on a dyno. obs's lack some fuel compared to the sd's.
not much smoke with 90cc of fuel.
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #7 of 24 Old 04-01-2013, 11:31 AM Thread Starter
97Strokin''s Avatar
Nothing like an sd but you will see some
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #8 of 24 Old 04-01-2013, 04:38 PM
NorcalPSD925's Avatar
mine smokes decent, i also have 130cc split shots, want a vid of it smoking?
96 7.3L, RCSB, Race truck
Only regular cab short bed OBS in Nor Cal!
NorcalPSD925 is offline
post #9 of 24 Old 04-01-2013, 04:49 PM
JBRIXEN's Avatar
Custom tunes will clear up most of that smoke
JBRIXEN is offline
post #10 of 24 Old 04-02-2013, 07:47 AM
mattyp1983's Avatar
Does anyone have a ts6 chip for my 97 powerstroke . I'm looking to buy one
mattyp1983 is offline
