Trans-Command Location - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-30-2013, 10:21 PM Thread Starter
nohsp4u's Avatar
Ok, so how many have installed the Banks Trans-command unit? The truck i bought had it installed per a receipt dated 2004 when the tranny was replaced. Ford stated in the reciept that the Trans-command was removed and the harness replaced to prevent warranty issues. I am not sure if the unit was removed or just wiring. I am hoping the later.
Anyone know where to start looking, i.e. where would the unit be installed, so i can see if it is still there? i have looked all over the frame rail and can't locate anything. truck only has 30k and 11 years since the trans went so i think i should be good to reinstall if i find it.
Thank you
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #2 of 7 Old 03-30-2013, 11:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Says removed and a new harness installed, so someone would have to put forth effort to have that reinstalled, not sure where it would be but my money is the harness going to the trans
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 04-01-2013, 07:07 PM Thread Starter
nohsp4u's Avatar
Kris,
That would be true for most anyone else but not me. I had Ken Imler diesel look at it today, No Banks turbo, No banks exhaust and the trans-command is most likely on the Ford service tech's truck that did the trans work. He should be the wear marks where it was most likely installed. Oh well, at least i have an aftermarket down stack, inner cooler and low mileage. Guess you can't have everything.
nohsp4u is offline
post #4 of 7 Old 04-02-2013, 06:12 AM
superduty4x4's Avatar
You're not missing much with the Transcommand anyway, I wouldn't be too upset that its gone.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #5 of 7 Old 04-02-2013, 08:15 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That intercooler cost like $1200, and having a down pipe already installed both help because they are a huge pain to put in anyway, get custom tunes and a valve body from jw or bts, you will be plenty happy with shifts and power then
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 7 Old 04-02-2013, 11:45 AM
Quoted: 88 Post(s)
Just to let you know the trans command would have be installed within a few inches of the trans on passenger side near where the harness comes out of the trans.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #7 of 7 Old 04-02-2013, 12:18 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
Mine was screwed to the pinch weld about where Jack said it should be. Look for a loose cable with a jumper installed in it. That's where the box would have been.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
