DD'ing with race tune question. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-28-2013, 12:00 PM Thread Starter
Hey guys, my truck is a stage one truck, its stock except for exhaust, intake, e-fuel and injectors.
it has stage 2 injectors, I had my chip tuned down for stage 1, but I also had a few stage 2 tunes put on there for when I upgrade to supporting mods.
Long story short, im having a tuning issue and I need to get a hold of a data logger so they can help me out. My stock tune, and my race tune(stage 2) are the only tunes that act correctly.
Is there any reason I shouldn't run it all the time on stage 2 race? Assuming I can stay out of the pedal, is there anything thats bad on the motor? like timing, pulse width ect?
thanks!
1997 F250 7.3 5 speed, 3.55s, D60, 4" Diamond Eye Exhaust, Napa Intake Filter, E-Fuel, 35" bfg mt's, stage 2 rosewoods/tuning, Gauges
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
--Henry Ford
csdwarf11 is offline
post #2 of 6 Old 03-28-2013, 12:04 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
High pressure oil may not keep up, and egt's to high, also over speeding the turbo, keep an eye on your gauges, and autoenginuity has soft ware to data log iirc
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 03-28-2013, 01:12 PM Thread Starter
I havn't had any issues with my hpop, it tests pretty strong and even full throttle pulls dont seem to throw a cel.
If I keep boost at reasonable levels is turbo over speed still possible? (can you over speed a turbo @ 10-25 lbs of boost) I understand full throttle 40+psi is bad for it.
egt's I have no issues keeping down, in a daily driving sense, when I punch it they spike, but I always have my eye on them.
--Henry Ford
post #4 of 6 Old 03-28-2013, 02:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Well with my personal experience I get boost to 32-36 psi often, so if you keep your boost normal than, and not so much as to over speed or over boost the turbo, and you seem to have a healthy hpop you should be fine, I tow in my extreme tune sometimes without adverse effect other than needing to down shift to keep boost up and egt's down when pulling a grade
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 6 Old 03-28-2013, 05:33 PM
JD3020's Avatar
You'll have no issues, if you drive with half a brain and not going WOT all the time. FWIW i tow quite often in my race tune with 2's.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #6 of 6 Old 03-29-2013, 08:09 PM Thread Starter
Awesome to hear, and I respect my truck very much so. I never beat on it, I plan on just leaving it in the race tune, and turning it back to stock when other people drive the truck.
--Henry Ford
