96 Powerstroke PCM Q? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-26-2013, 11:36 AM Thread Starter
OBS Strokin's Avatar
I just bought a Bullydog Watchdog for my truck. I am replacing a boost and Pyro gauge with it. I also bought the sensor docking station as well. What are all the parameters that my truck with show without having to buy the after market lines to the docking station?
P.S. I am wanting Boost, Pyro, Fuel Press, and HPOP pressure to show at least!
96 7.3 F350, 4x4, 5 speed, 6 inch skyjacker lift, 35 12.50 M/T Baja Atz, custom TW 6 pos, Banks Intercooler, BDP experimental fuel system, banks double shot water meth, Chromoly Push Rods, Swamps IDM Mod, 2nd Gen Wicked Wheel, Stage II AFE cold air intake, Down Piped 5 inch Diamond Eye exhaust, Gauges, ladder bars, upgrades drives lines yokes, on board air system, triple trumpet train horns, smoked head light and taillight housings, and 55watt HID kit!!
OBS Strokin is offline
post #2 of 6 Old 03-26-2013, 01:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Your fuel is a mechanical pump so you need an attachment for the bowl shrader valve, you should move the map line to get good results on the boost if you want it to read from the PCM
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 03-27-2013, 02:11 AM Thread Starter
Ok i got ya, and what you mean about moving the map? Where would ya move it to?
post #4 of 6 Old 03-27-2013, 09:02 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Move it into the y coming out of your turbo and into the heads
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 6 Old 03-28-2013, 01:44 PM Thread Starter
ok I think I got ya
post #6 of 6 Old 03-28-2013, 02:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It's black and where the turbo feeds into the y
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
