ts 6 pos problems - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-25-2013, 06:11 PM Thread Starter
ts 6 pos problems
I have a ts 6 position chip installed on my 02 7.3 and seems to having an issue.... It supposed to be stock high idle 50 75 100 110 tunes or something really close to that anyway it seems that the first 4 spots are high idle and only one hp tune and it's not that much any ideas why it's not working properly FYI I've scrubbed the terminals very well
chiefson is offline
post #2 of 4 Old 03-25-2013, 08:09 PM
You may not get an answer here.....this is the 94-98 7.3 forum.
Good luck either way.
Rob73 is offline
post #3 of 4 Old 03-25-2013, 08:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Probably a bad burn, you contact the seller of your chip for a fix?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 4 Old 03-25-2013, 08:56 PM Thread Starter
Yea I noticed that I clicked the wrong one after I posted it nbd
chiefson is offline
