New to diesel and want to learn - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-23-2013, 08:14 PM Thread Starter
nohsp4u's Avatar
Ok, as with most of you, my budget it tight so any mods i do will need to be cheap and show results. The better the results the more my budget officer (Wife) will allow expenses.
I bought a 97 OBS F350 4x4 crew with 7.3 PSD. First diesel i ever owned and love it. I drove cummins duramax for work but never got to drive the PSD. Now i own one.
I know so very little about these things so i am willing to learn, please do not BS me as i really want to learn.
PO states this rig has Banks turbo, banks exhaust and inner cooler. I found it has an inner cooler but the blue pipes crossing the engine and a friends description. I think the downpipe has changed as there is work on the passenger side pipe to floor board. I have no idea about the rest. She is going to Ken Emler diesel in sac for a look over.
She has 134000 miles and runs great, i want more. Wife wants to pull a 36' fifth wheel and i want power. First, i am looking at the attitude CTS and a Bank intake setup. What other low cost mods are recommended. I know the CTS is not cheap and will most likely fall off for awhile. Thank you
nohsp4u is offline
post #2 of 11 Old 03-23-2013, 10:41 PM
7.3powerstroker's Avatar
Don't buy an edge chip. Get a 6pos from beans or someone else. I ran an edge chip for years and have had a 6pos now for a year and it is so much better Better tunes more power runs better. No pulling over to re program **** just turn the knob! And as far as banks not many people run banks stuff on there 7.3. Seems to be more of a dodge thing. What kind of build are you planning for so we know where to direct you in the way of parts
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #3 of 11 Old 03-24-2013, 07:48 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
You will want to find out if the truck is a 1997 California model. The 97 Cali's had some differences in the fuel system (pulse dampener attached to the rear of the fuel pump), injectors (split-shot versus single shot), glowplug system, PCM (very hard to find by-the-way), and engine wiring harness that are good to know going forward. I don't know how much the Banks intake is, but I would save some cash and get a Tymar intake for it. You can DIY something similar, but do the research first (I recommend just getting the real deal). Whatever you do, do not use a K&N (or that type) system on it.
On these trucks, the transmission (if it's an auto E4OD) needs attention especially if you plan on heavy towing and increased horsepower, so don't overlook it. Get a better tranny cooler (something like the factory cooler from a 6.0L or a TruCool Max), an upgraded valvebody from someone like Brian's Truck Shop (BTS) or John wood Automotive, and a better torque converter. I'm sure others will be happy to add to all of this. Cheers!
Patrick Feeley is offline
post #4 of 11 Old 03-24-2013, 10:51 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Don't forget gauges, and easiest way to tell a Cali model is a sticker on the pass side valve cover stating it conforms to California emissions, should be written in light blue, if its black and silver it is not a Cali truck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 11 Old 03-24-2013, 07:33 PM
BR'sCrewCab's Avatar
Welcome to the forum. This is a great place to learn from those who have mods and know what does and does not work.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #6 of 11 Old 03-30-2013, 06:41 PM Thread Starter
nohsp4u's Avatar
"Don't forget gauges, and easiest way to tell a Cali model is a sticker on the pass side valve cover stating it conforms to California emissions, should be written in light blue, if its black and silver it is not a Cali truck" (don't know how to do that fancy quote so cut and past works) LOL
351, my decal look silver and black, funny since i just bought the montana truck and took it to Cali DMV to register. The DMV inspector could not find the label and i told him, maybe since it is diesel it does not have one. He signed me off.
Does a non-cali mean i have a better truck, since calis are usually bogged down with crap?
This truck is going to be a daily driver and when we buy it, tow a fifth wheel.
nohsp4u is offline
post #7 of 11 Old 03-30-2013, 07:19 PM
Quoted: 15 Post(s)
Not really. The Cali trucks' splitshot injectors are capable of flowing a bit more fuel that the federal versions, but they have some differences that can be a pain. Cheers!
post #8 of 11 Old 03-30-2013, 07:28 PM Thread Starter
nohsp4u's Avatar
Can splits be installed in a non-cali or is that too much work for the benefits?
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #9 of 11 Old 03-31-2013, 02:23 PM
OL' OutLaw's Avatar
you don't want them.
get the TS 6 position chip with Tony Wildman tunes
you want what they call "Stage I Injectors" which are 160cc injectors
you have 90 cc injectors now
the injectors, chip, and the Banks Intercooler (only good thing Banks makes for the 7.3)
will give you about 340 - 360 horse on the ground, and about 700 ft lbs of torque
which is about double what you have now..in fact, call this guy, he will help you, and he's a straight shooter, he helped me a lot, and we've become friends thru the process....hard to find nowadays....
Cary T "OBSWIZ" on here :
Please feel free to call
Cary at:
CT Performance
775-835-3569 8am to 5pm
Pacific time. M-Sat
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #10 of 11 Old 03-31-2013, 07:10 PM Thread Starter
nohsp4u's Avatar
I began looking at pricing for stage 1's. Found baby swamps but i do not think i could afford the crazy price. Any other suppliers that have more reasonable prices, or am i left to save my duckets longer? Also, to replace the sticks. i need to open the valve cover, so would it be smarter to change plugs also? if so, what would be a good mod? Any info with supplier would be gratefully appreciated.
nohsp4u is offline
