Glow shift fuel pressure sending unit location 95 powerstroke?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-22-2013, 01:14 PM Thread Starter
Trying to figure out we're to thread in my fuel pressure sending unit on my 95 ford PS it's a glow shift system
OBS1995 is offline
post #2 of 10 Old 03-22-2013, 01:35 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Side of the fuel bowl has a shrader valve, your gonna need to adapt it to that, it should be on the front right of the fuel filter bowl, more than likely has a black cap over it
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 10 Old 03-22-2013, 01:38 PM Thread Starter
Thank you sir, would you know off the top of your head how to adapt it cause it looks like the same thread size
OBS1995 is offline
post #4 of 10 Old 03-22-2013, 01:50 PM Thread Starter
Nvm I need some kind of 90 I just saw that
OBS1995 is offline
post #5 of 10 Old 03-27-2013, 10:05 PM
NorcalPSD925's Avatar
I wouldn't install it.. I went through 2 sending units in a few months with my glowshift gauge. The constant spiking of psi kills them. It's not smooth like the 99-03 cause they have electric pumps, just get a liquid filled mechanical gauge.
96 7.3L, RCSB, Race truck
Only regular cab short bed OBS in Nor Cal!
NorcalPSD925 is offline
post #6 of 10 Old 03-28-2013, 07:12 AM
superduty4x4's Avatar
Or buy a quality gauge. I have Isspro EV2's in my truck and my fuel PSI gauge has been swinging like Tarzan through the trees for 2 years now and it still works perfectly.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #7 of 10 Old 03-28-2013, 11:37 AM
Diesel Freak
yngbuck19's Avatar
No problems here with my glowshifts I've had a set of them on every truck I've had so far and thinking about getting their max tow gauges next
1997 F250 7.3 powerstroke SCLB HD XLT
340,000 Mi.
Blown Tranny Mod
D60 Swap
4:10's
DIY E-FUEL
PHP 6 pos.
S&B CAI w/Prefilter
EBPV Delete
3" DP
Kitty Delete
Cat Back 5"
Aeroturbine 5050XL Muffler
6" Vented Tip
S.S. HPX
17"X10" Pacers
4" Rough Country Susp. Lift
KW 17 LED CabLights
35"X12" BFG KM2's
Tint 20%
Magnum CB 104" Whip
Quad A-PillarPod
GlowShift Digital Gauges
Future mods: ??? 1.5 Sticks T500
1996 ECLB XLT SOLD
1997 ECLB HD SOLD
yngbuck19 is offline
post #8 of 10 Old 03-29-2013, 12:58 AM
jjones96's Avatar
I've got the max tow set and I love em. Wouldn't change a thing
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #9 of 10 Old 03-29-2013, 10:50 PM
bignate's Avatar
I added a T fitting where the schrader valve was. Schrader valve on one side and needle valve to sensor on the other. The needle valve is very important as the gauge would bounce 10-15psi with out it. Now it fluctuates 1-2 psi with the valve almost closed. Best $10ish I have spent on the project. Weatherhead WH-6820
1996 F250 4x4 7.3 5 Speed Ex Cab Short Box. Mods: 6637, 3"DP, 4" Exhaust, Beans 6pos Chip, Isspro 2 Pyro-Fuel-Boost, 255/85R16, 216,000 miles
Boost Fooler, 203deg Thermostat and Custom 12" sub center console on the way...
Wishing I was Fishing...
bignate is offline
post #10 of 10 Old 03-30-2013, 05:11 AM
Diesel Freak
yngbuck19's Avatar
A snubber would also work to keep the bouncing down a little bit
340,000 Mi.
Blown Tranny Mod
D60 Swap
4:10's
DIY E-FUEL
PHP 6 pos.
S&B CAI w/Prefilter
EBPV Delete
3" DP
Kitty Delete
Cat Back 5"
6" Vented Tip
S.S. HPX
17"X10" Pacers
KW 17 LED CabLights
35"X12" BFG KM2's
Tint 20%
Magnum CB 104" Whip
Quad A-PillarPod
1996 ECLB XLT SOLD
1997 ECLB HD SOLD
