7.3 Performance Help - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-19-2013, 01:21 PM Thread Starter
I have a 1995 Ford F-350 PS i just completed my 4'' custom intake and straight piped the exhaust. Also as we speak my Pyro, Boost and Fuel pressure Guage's are on their way anything i can do to the stock intake/exhaust housing on the turbo without buying an expensive *** banks system for quicker spool up?? Also chips and modules what would yall recommend i have a stock clutch in a ZF-5sp so nothing to much. And anything else performance wise is greatly appreciated Thanks For Reading
OBS1995 is offline
post #2 of 17 Old 03-19-2013, 01:27 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Get a custom tuned 6 position TS chip from tonywildman (call ct performance or stealth), PHP, GEARHEAD, swamps, beans, tyrant... A new comer is no limit tuning. No experiance with them.
Also in your 4" exhaust install, did u install a 3" down pipe. If not, DO SO!
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 17 Old 03-19-2013, 01:29 PM
White7.3stroker's Avatar
Send a message via AIM to White7.3stroker
Re: 7.3 Performance Help
I would look into a wicked wheel 2 i believe they have been making more power but still not cheap..and also id go with a 6 position chips from one of the custom tuners there are some guys on here that sale them..
Sent from my DROID X2
________________________ Early 1999 Crew Cab Long Bed
zoodad mod,Fog light mod,08tailgate,Harley lights,04 mirrors,built Tranny,diy intake,5" turbo back exhaust,DP tuner,glowshift guages,6"lift 20x12 fuel Octanes,33x12.50 Mud Grapplers...soon HID's,Led reverse lights,New tires lol,
White7.3stroker is offline
post #4 of 17 Old 03-19-2013, 01:31 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
and upgrade that clutch before you grenade it
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 17 Old 03-19-2013, 01:44 PM Thread Starter
I did a diamond eye 3" DP, cat delete and muffler delete with stock pipes.
I agree on the clutch but i just replaced it to a solid FW conversion but its definetly not a performance clutch.
Does wicked Wheel make one for my year? i havent seen one, i read that the exhaust side is to big for stock sticks but i could be wrong.
OBS1995 is offline
post #6 of 17 Old 03-19-2013, 02:06 PM
the baconator
Quoted: 153 Post(s)
well a SMF is much better than the DMF. Dieselsite just came out with a second generation Wicked Wheel, WW2. they make them for the stock turbos, the D66 and the 38R. i don't know what you are asking about the exhaust side being too big. unless you mean it is a 1.15 housing as opposed to a smaller 1.0 housing the smaller housing moves the boost lower in the RPM range, but IMHO it runs out of air way too fast on the top end even with stock sticks
post #7 of 17 Old 03-19-2013, 02:18 PM Thread Starter
I was just reading and a lot of people said to go to the 1.0 housing but i can see what you mean with running out of air in the higher rpm range. And ill look into the wicked wheel for it. I just want to wake it up some when i push the skinny pedal so maybe just a wicked wheel and mild tuning will do with the stock clutch. And next i need to look into gears cause im at 2100 rpm right below 60mph i think it has a 411 ratio.
OBS1995 is offline
post #8 of 17 Old 03-19-2013, 02:46 PM
the baconator
Quoted: 153 Post(s)
depends if and how much you tow. i tow alot and i tow heavy i like to keep the EGTs low. i also love my 4.10s then again i tow.
post #9 of 17 Old 03-19-2013, 03:04 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I would suggest custom tunes first, but like frank I say tony wildman, lifetime free reburns, and dieselsite makes the ww2, I have one in my pass seat rite now, after the reviews I can't wait to install it.
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #10 of 17 Old 03-19-2013, 03:44 PM
superduty4x4's Avatar
I believe No Limit is Jonathan, formerly of Bean's. Or is it Swamps... one of the two.
Tyrant is no longer tuning unless something has changed I hadn't heard about. And even if he is tuning, he seems to have problems tuning a 5 speed truck.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
