DIY Innercooler Help - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 109 Old 03-18-2013, 10:38 AM Thread Starter
BR'sCrewCab's Avatar
Guys,
Looking for some insight on the innercooler setups everyone is running. I have been surfing the internet enough to be officially confused. I am almost ready to pull the trigger on the Banks Kit with the Quick Turbo assembly. Here is my main question. Is there a DIY kit available. I see some pipe kits on ebay, and have seen a lot of threads mentioning kits, but a lot of those are from years back. I can line up a 6.0 intercooler, just need help with the piping and connections. Thanks in advance.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #2 of 109 Old 03-18-2013, 11:04 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
The DIY intercooler kit requires u to use a e99 spyder, any intercooler u want and a custom set of pipes. Weather u buy thoes pipes from a builder or make them yourself is up to u. Chris lahnom is the one who makes most of them but he is over seas right now. U can use SD intercooler pipes but u have to tweek the pipes with a little cutting and welding. All depends on your skill level.
Some one else will chime in on a good link. I dont remember it off hand.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 109 Old 03-18-2013, 11:07 AM Thread Starter
I can usually handle kits and instructions, but not capable of welding. The banks kit is appealing cause it fits my skill level. Also looked at the cx racing kit.
The Following 2 Users Say Thank You to BR'sCrewCab For This Useful Post:
martyanderson10 (05-21-2017)
post #4 of 109 Old 03-18-2013, 12:23 PM
ol_Blue97's Avatar
There have been 2 guys on here who have installed the crx kit with great results. Some just dont like it because it looks smaller but the core of the intercooler is thicker then a stock SD cooler. Regarless of what u do it will serve your purpose and keep the egts down nd u will be able to crank up the fuel a little
FRANK THE TANK
post #5 of 109 Old 03-18-2013, 01:04 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I ran the e99 spyder with custom cut pipes, and. 6.0 cooler, I've heard good things on the cx racing kit, and great things on the ats and banks kits, everyone seems skeptic on the cxr just Kause it's not a huge name here, but same good results, good luck with your choice tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 109 Old 03-18-2013, 01:15 PM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
ats is smaller. banks is great, but expensive. personally i am running banks spyder and pipes and a 7.3 cooler. got everything used
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 109 Old 03-18-2013, 01:48 PM Thread Starter
any feedback on the quick turbo housing from banks along with the kit. will it make that much of a difference in conjunction with the inter cooler?
post #8 of 109 Old 03-18-2013, 02:25 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Well the intercooler will slow the boost, so the quick spool housing should speed it back to keep it the same maybe more, I still have the factory housing and intercooler added but less egt's and lost maybe 4-5 lbs, but I can keep in it on the hills while hauling a load a lot longer than previous
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 109 Old 03-18-2013, 02:41 PM Thread Starter
I figured while I am up to my knees in it, might as well add the quick turbo housing as well.
post #10 of 109 Old 03-18-2013, 03:57 PM
ol_Blue97's Avatar
Dont get the quick spool from banks tho... call beans diesel performance, they are 1/2 the price for the same thing. And only install this if u dont plan on upgrading injectors.
FRANK THE TANK
