Is there a "BEST" electric fuel kit? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 21 Old 03-17-2013, 08:27 AM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
Yes, I know I can build my own electric fuel kit and save some money. However, I would prefer to buy a complete electric fuel kit with step by step instructions to save myself some headaches. Once I have done a kit, then I will know what it takes and perhaps build my own in the future but right now, I could use the all the guidance I can get. These are some of the kits I am looking at right now. Is one of these kits preferable over the others? Are there even better ones I am missing?
94-97 Power Stroke Complete Single Pump Fuel System
http://www.dieselsite.com/dieselsite...97ford73l.aspx
Buy Online | Irate Diesel Performance LLC
Comp Fuel System - Swamp's Diesel Performance
Driven Diesel 7.3L OBS Fuel Bowl Delete Regulated Return System (req. Elec. Pump Conversion) (This item is drop shipped from Driven Diesel) - Fuel System Upgrades - 1994.5 - 2003 Powerstroke 7.3L Truck - Ford Powerstroke
7.3 OBS Fuel System
I am original owner of 97 Extended Cab 4x4 with 86,000 miles, Unlimited Diesel 175/30 Stage 1.5 Injectors, ATS Intercooler, Tony Wildman 6 Position Chip, 4" Turbo Back Diamond Eye Exhaust, Stealth SPR1 HPOP, Wicked Wheel 2, Hypermax Combo Boost/EGT Gauge, DIY Intake, FPR Mod, CCV Mod, IDM Mod, 203 degree T Stat, Stainless Steel High Pressure Crossover Line, Fitch Fuel Catalyst, 40,000 lb. Trucool Max Transmission Cooler. Next up a Bean's D-66, electric fuel, torque converter and a valve body.
Frostbite is offline
post #2 of 21 Old 03-17-2013, 08:43 AM
Sam Burton's Avatar
well if you are looking for instructions don't buy the Irate kit.
i was thinking the same way as you are when i bought my kit, but it just came as a box of parts, i e-mailed looking for instructions and was ignored.
it is a nice kit and when i had the fuel pump fail they sent me a new one but the customer service certainly wasn't what i expected.
if i had to do it again i would either go with the Beans kit or just do it myself.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 21 Old 03-17-2013, 09:15 AM
IBEW Journeyman Lineman
PolarBear's Avatar
I also wanted a kit with good instructions and all the parts ready to go since this would be my first fuel system project. I ended up buying the Dieselsite CPR kit. It came with a great instruction booklet with large color pictures which made it a fairly easy install. I did have to make an after hours call to Bob Riley concerning the install and he helped me out no problem on a Friday evening. Now that I know what this project is all about, if I were to do it again I would probably source the parts myself to save some cash. But since not everyone is a mechanic or has the help and resources to tackle a DIY project like this, I would highly recommend the Dieselsite fuel system if its in the budget.
2012 F350 XLT CCLB 4x4 6.7
PolarBear is offline
post #4 of 21 Old 03-17-2013, 10:45 AM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
Thanks guys.
Honestly, I am leaning toward the Beans Diesel kit and I really can't tell you why.
post #5 of 21 Old 03-17-2013, 05:34 PM
i thought i read somewhere Beans had great color instructions.
joncolpron likes this.
03, 7.3 FX4, CCSB
Supporting mods from Strictly
No Limit Tuned
Ported compressor cover
Billet WW2
High flow outlet
RiffRaff FRX
Snow Water/Meth FOR SALE
AirDog 100
6.0 IC swap
AFE pro 5R
5" miter single stack kit FOR SALE
203 Thermo
TransGo
UNDER- -PRESSURE is offline
post #6 of 21 Old 03-17-2013, 05:48 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
i would recomend MARTY'S DIESEL kit, i will see if i can get a pic for ya
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #7 of 21 Old 03-17-2013, 05:56 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
And a link frank, I've never heard of this Marty
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 21 Old 03-17-2013, 06:30 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
marty as in marty's diesel. he lives in MD. does some work for innovative (i think)
and guys it really isn't bad to build your own. i went through it. hardest part is getting the fuse and relay in the factory box to look "factory"
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #9 of 21 Old 03-17-2013, 06:46 PM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
I'm sure once someone has done an E fuel conversion a kit seems like a waste of money. I have printed many lists of required parts to do the E fuel conversion from various posts. The parts lists never seem to match and everyone seems to do things a little differently. I want a tried and true setup that I can knock out over a weekend with having to run to the hardware store (that just closed) to buy more of something.
I wouldn't try to do the valve body or the torque converter on my truck either but, I'm sure once I did it I would think heck yes, I could have done this myself now that I see how things work inside the transmission. That's kind of the same thing i am feeling about an E fuel conversion.
post #10 of 21 Old 03-17-2013, 09:24 PM
I'm in the same boat. A complete kit with instructions, advice and being able to hopefully warranty something if it does not work right is sometimes worth what you pay. I'll be reading all those links. I'm leaning towards the Beans kit right now. If I come across an extra 5 hundy I may go with the diesel site kit. I've read their filters are harder to get. Beans looks like Napa filters.
ToddM715 is offline
