6.0 Fan mod - Ford Powerstroke Diesel Forum
post #1 of 54 Old 03-14-2013, 06:53 PM Thread Starter
Joe0816's Avatar
6.0 Fan mod
Im considering doing the whole 6.0 fan on the 7.3 clutch. Is it a drop in install or would I have to get a new shroud or do any other work other then swap the blades?
2001 F250 ECLB 7.3 PSD 219,000 miles
S&B Intake
Flo-Pro 5" SS Exhaust
ISSPRO EV2 Boost, Pyro, Trans
David Lott Tunes
Riffraff HPx, FRx & AIH Delete
Resse Gooseneck Hitch
Non-EBPV Turbo
Joe0816 is offline
post #2 of 54 Old 03-14-2013, 07:35 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Swap the blades only nothing else needed
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 54 Old 03-15-2013, 05:32 AM
Frostbite's Avatar
Quoted: 10 Post(s)
"Swap the blades only nothing else needed"
Really!
Is it possible to buy a 6.0 fan, remove the blades from the hub and swap the fiber 6.0 blades for the 7.3 blades while the fan is on the OBS truck?
Or do you mean, just swap the fans and leave the stock shroud on the OBS afterward?
2016 Ford F-350 4x4 6.7 Powerstroke, Lariat Ultimate Package.
I also still have my 97 Extended Cab 4x4 which I am the original owner of with 98,000 miles, Unlimited Diesel 175/30 Stage 1.5 Injectors, ATS Intercooler, Tony Wildman 6 Position Chip, 4" Turbo Back Diamond Eye Exhaust, Stealth SPR1 HPOP, Wicked Wheel 2, Hypermax Combo Boost/EGT Gauge, DIY Intake, FPR Mod, CCV Mod, IDM Mod, 203 degree T Stat, Stainless Steel High Pressure Crossover Line, Fitch Fuel Catalyst, 40,000 lb. Trucool Max Transmission Cooler. Next up a Bean's D-66, electric fuel, torque converter and a valve body.
Frostbite is offline
post #4 of 54 Old 03-15-2013, 05:43 AM
Cuzmail's Avatar
What does this mod do? Haven't heard of it before.
'05 F250 KR CC SWB
Mini Maxx
4" SS turbo back
AFE Stage II
EGR bypassed
Ravelco
Viper 5901
Train horns - of course !
Tool box, interior lights, & metal bed cover combo
'10 Tailgate with step
'08 Tail lights
'11 Rear bumper
Classic quote by Snake "Both of you should sell your trucks and buy imports with lots of stickers, big fart can mufflers, and a rear wing as tall as you can find. You'll fit in well with that crowd."
Cuzmail is offline
post #5 of 54 Old 03-15-2013, 06:07 AM Thread Starter
Joe0816's Avatar
Basically, the weight reduces from 10 to 4 pounds, better flow, and when the clutch engages, its quieter.
Really!
I mean swap the fans, use the 7.3 clutch and use the stock shroud.
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #6 of 54 Old 03-15-2013, 06:20 AM
Diesel Freak
yngbuck19's Avatar
Where do you find a 6.0L fan did a search last night couldn't find one. Just curious is this it?
http://www.rockauto.com/catalog/x,ca...,parttype,6808
Motorcraft PN -YA245
1997 F250 7.3 powerstroke SCLB HD XLT
340,000 Mi.
Blown Tranny Mod
D60 Swap
4:10's
DIY E-FUEL
PHP 6 pos.
S&B CAI w/Prefilter
EBPV Delete
3" DP
Kitty Delete
Cat Back 5"
Aeroturbine 5050XL Muffler
6" Vented Tip
S.S. HPX
17"X10" Pacers
4" Rough Country Susp. Lift
KW 17 LED CabLights
35"X12" BFG KM2's
Tint 20%
Magnum CB 104" Whip
Quad A-PillarPod
GlowShift Digital Gauges
Future mods: ??? 1.5 Sticks T500
1996 ECLB XLT SOLD
1997 ECLB HD SOLD
yngbuck19 is offline
post #7 of 54 Old 03-15-2013, 07:35 AM Thread Starter
Joe0816's Avatar
No its literally the fan in front of pulleys
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #8 of 54 Old 03-15-2013, 11:56 AM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
lock up autofair ford. he is a vendor here great prices
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #9 of 54 Old 03-15-2013, 04:18 PM
Frostbite's Avatar
Quoted: 10 Post(s)
Youngbuck19, that's the same part number I came up with.
I too wonder if it's the correct part number.
If it isn't, could someone please tell us what is the right part number?
post #10 of 54 Old 03-15-2013, 05:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The fan only, as in take it from the clutch and install it on yours
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
Tags
6.0 , 7.3 , clutch , fan , mod
