Is going to a lightweight 6.0 cooling fan considered a performance modification? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-07-2013, 04:44 PM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
I saw a post where an individual on the forum had installed a lightweight fiber 6.0 Powerstroke cooling fan. He mentioned it bolts right up to the 7.3 clutch fan without modification and flows 4 times as much air as the 7.3 cooling fan.
This could be a great mod for anyone towing, especially at low speeds or in the mountains. Also, with being so much lighter than the stock steel fan, this could theoretically reduce engine rotating mass making the engine accelerate a bit more quickly and perhaps it may even get a tiny bit better mileage. The price is reasonable. I see them on E bay for $62 plus shipping.
Has anyone else done this?
Are there any potential issues from doing this?
Is it a good mod to think about doing on a 7.3?
I am original owner of 97 Extended Cab 4x4 with 86,000 miles, Unlimited Diesel 175/30 Stage 1.5 Injectors, ATS Intercooler, Tony Wildman 6 Position Chip, 4" Turbo Back Diamond Eye Exhaust, Stealth SPR1 HPOP, Wicked Wheel 2, Hypermax Combo Boost/EGT Gauge, DIY Intake, FPR Mod, CCV Mod, IDM Mod, 203 degree T Stat, Stainless Steel High Pressure Crossover Line, Fitch Fuel Catalyst, 40,000 lb. Trucool Max Transmission Cooler. Next up a Bean's D-66, electric fuel, torque converter and a valve body.
Frostbite is offline
post #2 of 16 Old 03-07-2013, 05:21 PM
Yes good mod im on the hunt for one to better my cooling this summer towing the horse trailer
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #3 of 16 Old 03-07-2013, 06:25 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I've only heard good things, gonna head to the local yard and try to pull one tomorrow
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 16 Old 03-07-2013, 07:35 PM
toad's Avatar
Quoted: 19 Post(s)
I have one waiting to be installed. I have a 1500 mile road trip the end of the month. Half of those will be pulling a 14k 5th wheel. I will post up some feedback.
toad is offline
post #5 of 16 Old 03-07-2013, 07:53 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
It's not going to add HP. They only require 19 HP when fully engaged. The fan isn't fully engaged all the time therefore it will only save HP when the fan clutch is fully engaged requiring less force to spin this fan than the steel fan.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 16 Old 03-07-2013, 07:57 PM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
Good, I thought it sounded like a reasonable thing to do. If anyone scores more than one please let me know. I will be watching for one as well.
How hard is it to change? You don't have to remove the radiator, do you?
post #7 of 16 Old 03-07-2013, 08:03 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
I don't know on a 7.3 but if you look at this thread I just replaced my water pump with one from BulletProofDiesel today and removed my fan without removing the radiator.
::Water Pump Upgrade::BPD Water Pump Install Write-up::
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 16 Old 03-08-2013, 05:32 AM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
So Tuscany, I see by the fiber fan in the link you added, is the water pump change link on a 6.0? I assume so because my fan is definitely steel on my 7.3.
post #9 of 16 Old 03-08-2013, 05:39 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Yes it is. It was on my truck.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #10 of 16 Old 03-08-2013, 06:54 AM
JD3020's Avatar
Radiator stays. Gotta get the fan clutch tools to loosen the fan, then it comes out with the shroud.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
