Water to air intercooler - Ford Powerstroke Diesel Forum
Old 03-03-2013, 06:15 AM
Has anyone tried it? I mean cheaper, easy install, same results? I know the fear of a leak and coolant dumping in your motor but if u keep a good eye on your cooling system there shouldn't be to many problems. All the new trucks are coming with them. Any thoughts? And has anyone done it?
Old 03-03-2013, 06:59 AM
IMO it's a lot of extra weight with the extra coolant and circulation pump for no reason when it's a lot simpler to use an air to air intercooler.
Sent from AutoGuide.com App
Old 03-03-2013, 07:55 AM
Most of the aftermarket A/W systems use a dedicated water supply. They are great setups and are SUPER effective if you have the correct specs I/C size, water pump sixe, correct water flow through the I/C. But unless I was building some crazy all out monster, I will be more than happy with an air to air cooler.
