Custom Tunes and the ZF-5 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-01-2013, 05:40 AM Thread Starter
Ok guys, Currently I am running an Edge Evolution in my truck, I always run the 40hp tow tune. I have played with the 80hp "extreme" tune from time to time but until I get my pyro installed and new clutch I play it safe.
My question is, for those of us who have a ZF-5 bolted up behind our motors is custom tuning really worth double the expense over a generic TS chip?
I know the old saying "you get what you pay for" but most of the things I read about the custom vs. TS tunes has to do with Transmission tuning for the E4OD. I really have no problem spending $500 on a TW or beans or Swamps chip but only if i can justify double the expense of the TS 6 position which retails between $240-$270.
I am already running an MBRP downpipe/straight 4in exhaust as well as an intake so the foundation is already in place. I will be installing Pyro, Boost and a yet to be determined third gauge (most likely HPOP or water temp) and a clutch before I install the chip. Mostly I am justlooking forward do ditching the Evolution. Although I cant complain since it came with the truck but we all know when it comes to 7.3's edge < everything else.
Im interested in hearing everybodys thoughts on this.
matt-jenkins is offline
post #2 of 6 Old 03-01-2013, 09:27 AM
7.3powerstroker's Avatar
Okayy well custom tunes only apply if you have mods such as Injectors, turbo, or intercooler. You don't just get custom tunes on a stocker.
And as long as you have a 3"inch dp you don't have to be to worried about egts especially with that edge crap. I had an edge chip for a year or so and ran it on extreme the whole time. Never saw it go above 12.
Egts climb faster now that I have a 6pos so gauges is a good idea.
As far as a clutch goes. I have to 5 speeds and I run my 6pos on the highest tune all the time and I drive the piss out of these things. Haven't had a problem with the tranny or clutch yet.
Hence the fact you don't actually get 140 horse from the chip since stock injectors can only push so much fuel.
And as far as a clutch goes
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #3 of 6 Old 03-01-2013, 10:11 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Gauges are good to have on a stocker as well. I could get the 94 with a 5-speed up to 1300F on the pyro consistently when towing with the 5th wheel over the Sierras. Cheers!
Patrick Feeley is offline
post #4 of 6 Old 03-01-2013, 10:19 AM
Prob with a stock down pipe. But yeah if your towing gauges are necessary
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
99 Turbo and Spyder
6" Lift
37" BFG KM2's
CB Radio
Soon to come
Custom Rear Bumper
Headache Rack
rosewood stage 1's
custom tunes
post #5 of 6 Old 03-01-2013, 08:31 PM
Quoted: 13 Post(s)
The 1300F was with an open air intake (Tymar type, same filter), a 3" DP, gutted CAT, modified pedestal, and gutted EBPV. Cheers!
post #6 of 6 Old 03-02-2013, 11:05 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
short answer yes. but you can get the st and then get it reburned later
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
