Hp or Torque??
It might sound simplistic but i really dont know, i hear all the time
" i want 400 hp" Or i make it, but no one ever says what the torque is. Isnt that whats moving these 7000 pound beasts? So i guess my question is at 400 hp about how much torque is that? ?? |
Re: Hp or Torque??
700 rwhp my guess
Sent from my YP-G1 |
So 400 hp would equal around 700ft of torque? ??
Im probably wrong but that seems like alot |
probably closer to 750
Wow, i had no idea it'd be that high. So then 400hp would be
a screaming beast huh? I think id be happy with maybe 600-650 torque. Can i get there with factory injectors, ww2, chip/tuner and exhaust? Thx |
Factory injectors are only good for cores to get something bigger
Intake, exhaust, Stage 1's, good hpop, ww2 in stock turbo and tune it, you will have all the power you are looking for |
HP = (Torque * RPM)/5232, so you can see the horsepower will vary with the torque and engine speed. You can get the same HP with less torque at higher engine speed as you can with greater torque at lower engine speed. It kind of depends on what your application is (which for a truck is generally more torque at lower engine speed). Cheers!
Gauges too
Don't forget you will need gauges. Turbo, egt and trans temp if auto.
