I have a 1994.5 psd And I can't find good aftermarket performance parts most importantly a good turbo. I need a good supplier where I can get everything for a competitive price. Help please??
what are you looking for?
we have lots of great vendors who are sponsors of the site. as for turbo, there are a few direct replacements but on the OBS until you upgrade a bunch of other stuff you don't really need to upgrade your turbo. |
Yup, a lot of things can happen before a new turbo is needed, if you need a new one, I would just rebuild it
How are you searching for parts on your truck... if u use 94.5 or 94 u will find nothing. Try using 95 and see what happens
Yes I intend to put stage 3 injectors, straight pipe, an inter cooler,a three inch down pipe, a tw 6 position and an aftermarket turbo because everything I see about stock turbos says 450 horse power is about all it can handle without overspeeding the empeller which can be dangerous. Also what other aftermarket performance parts would be good because I want to push close to 600 or more horspower
a true 600rwhp is going to be expensive, on top of youre mod list youll definately need a bigger fuel system and would require a full engine build with aftermarket rods (to be reliable), dual or a big HPOP, cam, head work, studs, the list goes on.
Yes sir I know it's gonna be a big bill I just need to know where I can find all those parts and that are good quality also. This truck belonged to a very good friend of mine and he died last January so just a little over a year ago now and I want it to be one of the nastiest trucks around in his memory. I plan on doing all the things you mentioned I just don't know a good supplier for them.
Injectors-- full force, swamps, rosewood
Hpop-- terminator, srp1.1, adrenaline Fuel system-- Marty's diesel IDM -- get the HFHV idm from swamps Intercooler-- banks, or get a SD (aftermarket or stock) intercooler with custom pipes Camshaft-- gearhead (if u want to go this far) Head studs-- ARP or H11 Fire ring headgaskets -- carsons, they can also do port and polished heads Aftermarket pushrods and upgraded valvesprings Turbo-- get a T4 mount kit form Irate diesel and a turbo to match your injectors form him. He will aslo make custom pipes to fit your needs 6 pos chip--- tuner of your choice, PHP, Gearhead, Swamps, Tony Wildman.. For 600hp id do aftermarket rods and half a block fill, stock fordged rods are maxed at 550. Or just let er rip and keep a spare motor around to to build incase, may be cheaper this way. |
We can help..we have everything to mod a OBS..performance or suspension from mild to wild.
PM me if I can help. Cary |
| Tags |
| performance parts 7.3 psd |
