Another DP Install question(s) - Ford Powerstroke Diesel Forum
Old 02-20-2013, 09:27 AM
Now that spring is around the corner, going to tackle the 3in. downpipe install in my 96 f350. First, cutting out the old one. Any reason not to use my buddy's plasma cutter instead of the saws-all?
Second, going to use a porta-power to "re-size" the firewall so hoping no issues there?
Third, can I retain the heat blanket on the firewall if I give myself enough room with the porta-power?
Thanks - Bill
Old 02-20-2013, 09:48 AM
I don't see why you couldn't use the plasma cutter provided you aare careful (heck its pretty easy to whack through the uppipe with the sawzall if you're not careful). You want to keep the heat shielding on the firewall, and the seam will be lower than it (you'll see when you get in there. Cheers!
Old 02-20-2013, 10:41 AM
Thanks for the info. Now if I can just get the weather to cooperate!
Old 02-20-2013, 10:45 AM
Illiana Chapter Director
My buddy caught his 97 on fire using a plasma cutter. It's easy to cut with a sawzall.
Old 02-20-2013, 10:52 AM
Re: Another DP Install question(s)
Why not just use a sawzall it takes like 30 seconds
Sent from my SAMSUNG-SGH-I847 using AutoGuide.Com Free App
Old 02-20-2013, 11:04 AM
In reading other install posts, it seemed that some really wrestled with the saws-all method. I have access to the plasma cutter, so I figured why not?
- Bill
Old 02-20-2013, 11:18 AM
Get a fire extinguisher.
Old 02-20-2013, 11:23 AM
Please dont be offended for my pointing out the obvious but as a welder and lover of fresh cut metal, I always look for flammables in the background of my worksite. Be cautious of leaked oil, fuel and any other flammable substance to properly avoid a cataclysmic fire in your beloved truck.
Old 02-20-2013, 12:28 PM
No offense taken. I fly people all the time that have done really stupid things with flamables. If I can't do it safely, without threat of fire, the saws-all will be second at-bat.
Old 02-20-2013, 01:50 PM
I used a 9" Bi-metal blade with plenty of cutting fluid and didn't have any issues. Cheers!
