just bought truck with programer on it - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-17-2013, 11:23 PM Thread Starter
zigzbox's Avatar
okay i just bought a 96 with a f5 dp tuner and have no clue what the tunes are is there anyway to find out or do i just keep guessing so far i figured 5 is most performance and 2 is high idle and guessing 1 is stock so any help would be good plus sadly i think my truck might have something wrong with it cause it feels like it has no top end when im in any stage other than 5 maybe something wrong with programer or i really dont know thanks for the help guys
zigzbox is offline
post #2 of 4 Old 02-18-2013, 12:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Have you asked the previous owner? You could always send it in to find out the tunes, or have it reprogrammed, I'm not sure if dp-tuner would keep customer info like that on file, good luck tho, and in the tow tunes typically they are designed to de-fuel at higher rpm/speed to keep egt's down
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 02-18-2013, 12:24 PM
Justin@DP-Tuner's Avatar
Quoted: 60 Post(s)
You will find all of the info you need right HERE...
Let me know if you have any other questions.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 4 Old 02-18-2013, 11:40 PM Thread Starter
zigzbox's Avatar
thanks guys that helps alot and ya the tow tune now starting to make alot of sense, well now that i figured out what im going to do to the truck im probably going to just pick another programer with new tunes after i get some work done to it! this is my first powerstroke and i want it to make good power and be very reliable haha thanks again guys
zigzbox is offline
