6 speed?
Alright I got a 96 7.3 with a 5 speed manual transmission, I want to know if I can swap a 6 speed from the newer 7.3 models and what the benefits would be?
Sent from my Motorola Electrify using AutoGuide.Com Free App |
U can but its not a direct swap. U will need to custom make a trans cross member, add a trans cooler and lines, swap the t-case, shorten rear d-shaft, lengthen front d-shaft.
No real benefit then a slightly higher 6th and a lower 1st with less span in between each gear. Just leave your 5 speed in! |
What he said but I say go for it, I want a 6 speed obs too
Re: 6 speed?
Don't let others stop you, if I had a truck with stick I would do it
Re: 6 speed?
I had a semi on topic question about this do you guys think it would be worth swapping in a zf5 for the e40d. What would it entail to to do it and what benefits could I see. Goal for the truck is approxamently 550-600hp
Sent from my HTC VLE_U using AutoGuide.Com Free App |
So your getting rid of auto and going manual? Pretty much same stuff, drive shafts are different lengths, not sure about cross members tho, and you will need PCM to be tuned not to throw transmission codes
So not worth it?
Just depends on if you want stick or just have your auto built to hold up to that kind of power
Re: 6 speed?
Well I love driving stick but what would be the price difference do you think
