Re-use fpr? - Ford Powerstroke Diesel Forum
Old 02-09-2013, 06:43 PM
Re-use fpr?
Guys i am doing an electric fuel conversion on my 97 psd and need to get the truck going again. I want to re use the stock fpr. What do i need to mod on it to use it?. Pictures?
Old 02-09-2013, 08:22 PM
From what I've seen you can't.
Old 02-10-2013, 08:05 AM
Full A-Team Member
Yes you can, but I would get one that you can adjust pressure on
Old 02-10-2013, 09:47 AM
I am going to order a fuellabs regulator in a few days. I just want to use the stock one to get me going until then. We'll see if i can make it work.
Update: Made the stock fpr work for now. I just got too shim it and it should be dandy. Ordering an adjustable unit in a few days. But at least the truck runs.
Old 02-11-2013, 08:58 PM
Cool. How did you do it?
Old 02-11-2013, 09:33 PM
We need some piks of this
Old 02-12-2013, 01:46 PM
I did and it works great! But, if you are going to order one, I would hold off and do it one time. The mods for the factory FPR takes about an hour to do, gutting/grinding/and getting the right brass part (see "Tightwad mod" on this post or other forums, where I got the idea from)!!!!! I have 65 psi at idle and WOT. It only cost me my time and made my initial expense a little cheaper. If it ever has a problem, I will swap out with an adjustable one.
