cant decide which clutch!!
Im in the process of doing a zf5 swap in place of my e4od. I dont know which clutch to get. Horsepower or brand. My truck has stage 2 injectors d66 turbo elec fuel intercooler amd ts chip. I was thinking the southbend 500hp single disk. I also found a nice kit on Phoenix friction.. never beard of them though. Any help/input is appreciated
i have a southbend when it goes i will go to their highest HP single disc. i have only recently heard of phoenix. don't know much about them. there is also luk and valair
I put a kennys pulling clutch in mine, cost 550$ for everything 3600# pressure plate, its a button clutch, holds my 30 pound boost launches no problems yet. I have almost the same mods as you but rosewood stage 2s in mine. They're located here in ky I lot of guys around here run them they're cheap and quality built.
I'm running a Valair. It's the stock HP clutch that has about 50k on it, about 10k of that is since I chipped it. It holds whatever I can throw at it in the top tune (I should be making 350 HP, never had it on a dyno), but doesn't like to get hot in a boosted launch.
if you have it built up you might need the double disk, but they are loud and hard to get in gear. it depends on what you use the truck for but i just swapped out the stock dual mass flywheel setup for the valair in mine. so far its not too bad. make sure to add an extra quart of tranny fluid for a single mass flywheel though if gear chatter will annoy you
Im buying from kens pulling parts when mine starts goes. Apparently its tough if its holding 30psi launches lol, not sure how you are doing that, but I really want to know
Its simple hold the clutch in with the left foot hold the brake and go pedal with the other ease into the go pedal let out on the clutch do a John force Smokey burnout and when you dump the clutch watch the boost gauge, my clutch doesn't mind it yet my tires and stock charger are getting annoyed, and my wheel hop is getting old. Time for caltracs and a s366...
So your slipping the clutch to load the engine to build boost? Id say thats one tough clutch! Thats for the input
! even more excited to get one.What are you running for injectors ect? I also need to upgrade turbo lol, it doesn't seem to be causing a problem yet, but I know it cants like 40psi |
Im surprised your having boost issues, Thats a good idea though, put a regulator in the line to keep the turbo alive??..because its really hard to stay down to earth with the way my truck runs, boost climbs so fast past 35. I have the same 3.55's 5 speed, with 35" tires. She turns a tad under 1500 @ 55 lol. That works out to a top speed of about 140 lol, havn't had the stones to try it yet, curious if it has enough power to though. |
