t500 difference - Ford Powerstroke Diesel Forum
Old 01-27-2013, 08:58 AM
t500 difference
i just installed rosewood stage 1s yesterday amd i want to know if upgrading to a t500 is really worth iy. what would i belooking at difference wise?
Old 01-27-2013, 10:05 AM
The big thing to look at it duty cycle and HPO pressure. If you are keeping the pressure high and the duty cycle low, you will notice very little difference. But if you pressure is dropping off and the duty cycle is going up, then the T500 will make a noticeable difference
Old 01-27-2013, 10:12 AM
How do I check duty cycle and hop pressure and what are these?
Old 01-27-2013, 11:04 AM
You need a GOOD scanner or scan gauge
Old 01-27-2013, 11:08 AM
What should they be at? What's the numbers that make it worth getting it?
Old 01-27-2013, 11:12 AM
Even with this shouldnt it make a difference since I have a 15* pump
Old 01-27-2013, 11:16 AM
It depends how good your 15* pump is
Old 01-27-2013, 11:21 AM
So you're saying a 15* stock pump good condition is just as good as a 17* t500?
Old 01-27-2013, 04:46 PM
Full A-Team Member
Put your chip on extreme and stomp on the gas, does it throw a CEL? If it did, test done, get a T-500
Old 01-27-2013, 05:02 PM
LOL, yeah that works too
Tags
big, hpop, mod, oil, t500
