What to do with MAF sensor
Put a 6637 filter on from napa wondering if I need to cut a hole in the top of the filter to plug the sensor back in or what other people did? Any info would be great
![]() Sent from AutoGuide.com App |
Are you referring to the filter minder?
The factory filter minder is not correct for the application when using an open element. It will probably read like the filter is plugged when it is not. If you are refering to the Intake Air Temperature (IAT) sensor, just tie it off to the inner fender near the filter (that's what most folks do). Cheers!
Perfect thanks for the help must be the IAT was right beside the fender on the stock air box ill tape it up and call it good
Dont tape it up, leave the element open so it can still read temps, just throw a zip tie on it so its secured.
