'96 7.3 Turbo - exhaust brake suggestions please - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-21-2013, 02:04 PM Thread Starter
Interested to know what anyone recommends for the above w/auto trans. I pull a 9,000 # fiver and need braking power. Appreciate any advice you might offer.
whaley96 is offline
post #2 of 6 Old 01-21-2013, 02:31 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
not advised on an auto trans unless its a BTS trans thats guranteed for life.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 6 Old 01-23-2013, 06:23 PM
95redrifle's Avatar
Quoted: 4 Post(s)
Or if you have a TC lock-up switch of some sort it would be fine. Im not sure who makes one for the 7.3 but you could do the ebpv switch
Sent from AutoGuide.com App
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #4 of 6 Old 01-25-2013, 05:54 AM
ryandamo's Avatar
i only reccomend using the exhaust brake at higher speeds when the tranny is in overdrive or 3rd. its not good to lug the transmission at low speeds with an exhaust brake. If you wtill have the factory warm up valve on your turbo, you can use that by running a switched 12v power source to the plug under the compressor wheel of a turbo, mine worked pretty good.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #5 of 6 Old 01-25-2013, 06:01 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
, but if your gonna do it a TC lock up, and ebpv will work...lots of threads on how.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #6 of 6 Old 01-26-2013, 05:47 AM
ol_Blue97's Avatar
I guess i should have explained my self.... with a TC lockup at puts all your braking pressure on your coasting transmission clutches which are very light. I think only 3 clutches. Its just a matter of time b4 you wipe these clutches, fill your trans with metal, and u know what happens form here. So unless u have a BUILT trans(with a TC lockup) or a manual i would not suggest a exhaust brake, i was looking into this heavily and even designed a solid state controller to work automatically as i let off the gas and such to activate and lock the TC and once shifted down to 2nd it would turn itself off, but was discouraged by the transmission issue that i was unaware of. And this info came form a very well respected sponsor on this site, so i trashed the idea. JMHO... if you still want to. There are plenty of write ups on this. It involves using a switch to drive a double contact relay, one set of contacts to lock the TC, and the other to close the EBPV
FRANK THE TANK
