Should i do electric fuel?
hey guys i need some help. im planning on putting in stage 1 injectors and an intercooler. i was wondering if i should do electric fuel? ive seen some things on here. not entirely sure how to do it. so any advice would be nice. Thanks!
Dont need the electric fuel but in the long run itd help depending on how much hp you going for! But on stage 1 and an intercooler youd be fine with the stock mechanical fuel pump! Is that all the preformance you are doing or no?
Sent from my SGH-T679 using AutoGuide.Com Free App |
for now yes. i was thinking about a d66 turbo if i find one. i might even do more later down the road. but right now thats all i could do. i dont want alot of hp. the trucks my daily driver and i tow flat bad with it. just a few extra horse is all i need.
Then maybe do an HPOP, elextric fuel system if you do a d66! Cause the mechanical fuel system will give out and youll get fuel cut! Also if your looking for for a 66mm turbo try the domenator 66 from beans diesel! Great turbos!
okay! i prolly wont do a turbo for a while so im worried about that. is there like a certain HPOP i should get? i have looked at beans turbos they are good!
Just get a HPOP outta a newer 7.3 like 99-2003 superduty and you be fine!
Or a terminator HPOP made by Terminator!
okay i see, i hearing that somewhere now that i think about it. are they easy to install?
i remember hearing *
No but yes....you gotta take valve covers off! I mean easy all it does is replace your old HPOP and you slide new on in! May look it up just pictures on an install ive done some but on a new 7.3l which was a little hard to do cause of all the stuff! Where are you from?
