ELC Coolant Change Over
Changing over to an ELC. The work list for the weekend; flush cooling system, replace water pump, thermostat (203* from Dieselsite), upper water outlet, upper and lower hoses, all gaskets, fan clutch, and 8 gallons of Delo ELC coolant. I will also be using Fleetguards Restore and Restore Plus for the flush.
Anyone have any recommendations or would do anything different? |
International says not to use ELC coolant in the 7.3 if it was made prior to '99. That conventional green coolant is the proper coolant.
Not to use or they started to say use of ELC is permitted when ELC was introduced? I have many that have changed over
Sent from my SAMSUNG-SGH-I717 using AutoGuide.Com Free App |
I can't find the TSB but from gooch's flush procedures
http://www.superdutypsd.com/coolant_flush.php Quote:
The SCAs is what you need to be worried about. Use regular coolant and sca bottles or get coolant that is pre charged with it
http://www.dieselpowermag.com/tech/f...ooling_system/
This was posted over at diesel power mag check it out maybe we can have a discussion over this. |
If u were to do this i would remove the water jacket plugs in the block and flush the whole engine with distilled water to remove all the green. The reason guys use CAT coolant is because its pre charged with SCAs and other additives and combine that with a coolant filter and u have coolant that should last a long time. With out a coolant filter, no reason to spend the cash on cat coolant when u should be changing it out like regular coolant,
I have wondered what will happen when the conventional green coolant is no longer available. Around here Orielly's is the only place to get it. Napa, AZ, Advance, Auto Parts, none of them carry the green stuff.
Re: ELC Coolant Change Over
What would be the best coolant to use anyone recommend anything?
