Im not an expert or named cary..... but the angle of the swash plate is what pumps your oil, a more aggressive angle pumps more, but for what ever reason they dont go over 19*, maybe results start going backwards after that?? Idk
Piston size or swash plate...bore and stroke..either will increase displacement..swash plate..lifts the piston futher out the bore..so Stealth went back to stock 17* and kept the larger bore.
Well what pump would you recommend for those injectors Cary?
One with the best warranty
Cant beat stealth in that department.
cary - question - not looking to start anything - have they completely fixed the problems with the SRP 1s with the new 1.1? and what does the warranty cover if something goes wrong?
Gary continually is looking to improve his products..many changes have been made to the new pumps. I've got 3 on mine trucks.
Warranty covers the entire pump. |
the stories that scared me were the ones where people said it sent metal shavings throughout the block
When a pump fails any pump it stops pumping..so odds of any pump failing stock or modded sending debre into the system are minimal if at all.
okay. that makes sense
