Supporting Mod Question
I am looking at getting rosewood stage twos, and I understand the tranny takes a beating. Well I have a jasper rebuilt tranny with a shift kit. Does the shift kit help out or do i absolutely need a torque converter?
The shift kits helps but you do need a TQ converter. Even with a TQ converter and shift kit the trans isn't going to have a long life with stage 2s if driven hard.
Jasper isn't know for being strong....
You will also need a elect fuel system Big turbo..modded H2e kit best. Head studs Valve springs Better HPOP..SRP1.1 custom tunes Better filter..Tymar Exhaust. Intercooler will be a must BTS trans.. |
Eventually I was going to do e fuel and a d66. Head studs to my understanding won't be needed until about 45 psi, remember its a 7.3l were dealing with. My exhaust is fine. 3"dp to 4" to 6" stack. What filter are you.talking about? And intercooler eventually also. I'm in between a t500 hpop or a d66 turbo for the first supporting mod. Can't afford both.
I don't need to remember I only mod 7.3 engines....You can pop head gaskets at less than 45psi..plus you can easily make 45 with stage 2's....but its your risk.
K&N's are not for turbo diesels..you need a big Donaldson filter. |
I would listen to what cary says, he knows his chit. And that jasper won't hold up. I would go with a known, trusted valve body unless you know what is in there, and also a good TC (pi stallion, dpc, or I know cary offers some others too) to give it a fighting chance.
| Tags |
| injector, jasper, kit, rosewood, shift |
