Gauge Wobble - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-06-2013, 07:56 AM Thread Starter
OBS Strokin's Avatar
Gauge Wobble
Hey I need some help if anyone has suggestions? I have Auto meter sports comp gauges and my boost gauge starts to wobble and flicker threw the boost levels starting at about ten and all the way up... It will flicker between about 5 pounds back and forth...is this due to where the sensor is mounted? I heard I can use a liquid filled gauge but I do not want to dumb money for more gauges.... thanks for the help!!
96 7.3 F350, 4x4, 5 speed, 6 inch skyjacker lift, 35 12.50 M/T Baja Atz, custom TW 6 pos, Banks Intercooler, BDP experimental fuel system, banks double shot water meth, Chromoly Push Rods, Swamps IDM Mod, 2nd Gen Wicked Wheel, Stage II AFE cold air intake, Down Piped 5 inch Diamond Eye exhaust, Gauges, ladder bars, upgrades drives lines yokes, on board air system, triple trumpet train horns, smoked head light and taillight housings, and 55watt HID kit!!
OBS Strokin is offline
post #2 of 9 Old 01-06-2013, 09:13 AM
dr.deere's Avatar
Quoted: 19 Post(s)
i have the same issue and done some searching on here and everybody seems to say that you need to install a 90 deg fitting in where you teed in to map line or put fitting in intake spider. there was also an article in diesel power magazine where they got 500 hp out of an obs they used an autometer fuel snubber to stop that in the boost gauge. i haven't gotten around to putting a 90 in mine to see if it helps yet
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 9 Old 01-06-2013, 10:51 AM
Too cool for school
taylorking's Avatar
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
Does it make a hissing or clicking noise too? I had that with my Isspros. Got a package in the mail from them out of nowhere one day, and it had a little brass fitting in it that goes in the back of the gauge. Basically it had alot smaller hole in the middle than the original one. Chokes the airflow down a little. Fixed my issues
Typical cummins owner.
taylorking is offline
post #4 of 9 Old 01-06-2013, 10:52 AM
95redrifle's Avatar
Quoted: 3 Post(s)
My boost gauge was t-d into the map line and it would flicker. So i moved it to the intake spyder and i have had zero problems since
Sent from my iPhone using AutoGuide.com App
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #5 of 9 Old 01-08-2013, 07:42 PM
dr.deere's Avatar
Quoted: 19 Post(s)
95redrifle when you put yours in the intake spyder did you just drill and tap a hole in the spyder or weld a bung in. wondering if the spyder is thick enough to get enough threads to seal properly? i put a 90 in my tee in map line helped but still have flutter so looking to redo it totally
dr.deere is offline
post #6 of 9 Old 01-09-2013, 04:06 AM
95redrifle's Avatar
Quoted: 3 Post(s)
Yes i drilled and tapped the spyder. You have to be careful where you put it because like you said it is too thin in some spots. I put some plumbers tape on mine and it seals just fine. You can see in this pic where i put mine.
tony
1997 F250 4.10's
south bend clutch
post #7 of 9 Old 01-09-2013, 05:41 PM
dr.deere's Avatar
Quoted: 19 Post(s)
thanks that answered all my questions maybe ill have time to get around to trying that this weekend
dr.deere is offline
post #8 of 9 Old 01-10-2013, 09:45 AM
bucwheat's Avatar
Good advice here.
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
post #9 of 9 Old 01-10-2013, 09:52 AM Thread Starter
hey thanks for the replies!! And yes it makes kind of a high pitch flicker noise....and what do I need to get to do the 90 degree elbow and from where??
