TW tunes on SCT?
As soon as i have the cash i am going to get a chip for my truck and have pretty much settled on the TW tunes. I like the SCT livewire as it eliminates the need for pillar gauges, but can TW tunes be loaded to it? If so what are the advantages and disadvantages?
Sent from my iPhone using AutoGuide.com Free App Last edited by mathewsz7; 01-04-2013 at 03:10 PM. |
Shoot Cary at CT Performance a PM or email. He is a distributor of TW, and will be able to answer any questions you have.
Could I use the chip with a digital monitor rather than gauges? If so, what would be a good monitor?
Sent from my iPhone using AutoGuide.com Free App |
Yes you can use a TW chip and a digital monitor or TW can put his tunes on a SCT.
A friend of mine had his Edge Evolution on his 6.0 set up so that the engine would not turn off until one of the numbers on his monitor got to a certain point, even when the key was off. I saw this when I was even more diesel illiterate than I am now. Does anyone know what this might be? Is it very beneficial? A couple months ago I was told it is the same reason you let your engine idle for several minutes before shutting down after a long trip... Can other devices be set up to do this?
I'm assuming that would be a turbo cool-down timer. Prevents the engine from shutting down and oil coking (or burning) on the turbo journal bearing while EGT's are still up.
Again, I'm not sure what units can/can't be programmed with that option. If you still have the paperwork for your SCT take a look. I doubt that is something you would have to get customs tunes for. |
I don't have the SCT, just liked the looks/functionality.
Now I am leaning toward a 6position TW chip and either pillar gauges or the insight CTS. The Fd I'm on gets a deal on edge products so I would get the CTS for pretty cheap and would have the versatility of what I can monitor rather than just the three gauges I chose, and it would be much cheaper. Thoughts? |
Could always go with a triple gauge pod, two standard gauges and then the third being a aeroforce interceptor scan gauge. Personally, I like having standard gauges due to the fact that if one fails, I can still monitor all of the other inputs.
On the other hand the CTS is a nice unit. The fact that it has a backup camera incorporated is a nice touch. Definitely on my wishlist. Really it is up to you, and what suits your needs best. I would definitely get a standalone (TS) chip. That way as your truck progresses and you needs reburns, you still have gauges. |
