Need some help quick - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-29-2012, 09:34 AM Thread Starter
Ok, so I got a TS 6-position chip for Christmas (1996 f250 psd) Now when i start the truck in any of the settings, except high idle, it lopes until i mash the throttle and get it to stop then it runs fine. Also, the wait to start light just flashes and doesnt stay on for a full cycle. I pulled the chip and put the truck on a scan gauge and checked some vitals. My ICP pressure at idle stayed steady around 580 psi. Cranking it went to 1014 psi then to 580 at idle. My IPR percentage was steady at 16%. The truck did have the P0603 Internal Control Module KAM error. Then when my mechanic did a "key on engine running self test" it threw 2 new codes. One for EBPV but thats wired open so i expected that. The other was a P1705 not in park or neutral. Basically what im asking is, what here is normal and what all this $hit means. Thanks, Jeff
Strokin96! is offline
post #2 of 11 Old 12-29-2012, 12:14 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Where the contacts on your PCM cleaned very well? The kam, and ebpv ones are normal tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 12-29-2012, 04:00 PM Thread Starter
Ya my buddy cleaned them real well. I might run over them one more time when i get more time. Numbers and pressures look good?
post #4 of 11 Old 12-29-2012, 06:58 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That I couldn't say for sure I only have a gauge to monitor my hpop pressure idles about 500psi and under load goes all the way to 32k psi iirc, don't have anything to watch icp or anything like that, hopefully someone can chime in and help better
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 11 Old 12-29-2012, 07:54 PM Thread Starter
Well i do appreciate the help. Ill do some more research and try to figure it out. Thank!
post #6 of 11 Old 12-31-2012, 04:05 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
your numbers are fine the psi is the pressure the HPOP is supplying the % is how hard the pump is working, the higher the % the harder it is working. the KAM error is the pcm lost power at some point and hasn't reset (i believe)
but i agree with kris that you probably have an issue with the contacts in the pcm. or a faulty chip
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 11 Old 12-31-2012, 04:34 PM
jjones96's Avatar
The kam code is keep alive memory. Any pcm with a chip or tune has that code
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #8 of 11 Old 12-31-2012, 06:38 PM
backwoodsboy's Avatar
KAM code is a result of chip installation. Presumably, you disconnected both batteries before removing the PCM to install the chip? If so, there is your KAM Error. If not, you have bigger issues.
ICP and D.C. numbers look reasonable.
The fact that your WTS light doesn't stay illuminated tells me either:
1) the terminals on your PCM are not completely clean. Remove the PCM and use acetone and a scotchbrite pad to remove all of the silicone. Use a tooth-pick to get in between the 'fingers' on the pcm terminal. Just scrubbing with a scotchbrite pad will simply push the silicone into the areas next to the ridges. If you haven't done it before, take your time. Avoid removing any of the tin from the terminals if possible.
2) The chip has been programmed for an incorrect PCM strategy. Did you order the chip yourself, or did someone else place the order?
Chrome don't get ya home
backwoodsboy is offline
post #9 of 11 Old 01-11-2013, 01:26 PM Thread Starter
Sorry for the delay guys. Thanks for all your help. I'm gonna re check my connections. My dad ordered it for me but he had exact instructions so it was tuned right. I called the guy i bought it from and it was tuned right. Ill try and see if all silicone is off and by chance a little tin comes off is that the end of the world?
post #10 of 11 Old 01-11-2013, 03:05 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Just asking. Your friend that cleaned the PCM contacts before the chip install, he cleaned BOTH sides of the board not just the side that you can easily see right? Who's tunes are on the chip? I've had this issue with Beans tunes.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
