How much HP am I making?? - Ford Powerstroke Diesel Forum
Old 12-25-2012, 10:36 AM
I'm planning on puttin the following on my truck:
-4" stack kit
-3" downpipe
-AFE high flow intake
-TS 6 position chip (50-140hp)
-cat gutted
Once I've installed all of these mods, how much toque and horsepower will I be puttin out?? ( the truck I'm putting the mods on is the one in the signature )
Thanks
Old 12-25-2012, 11:04 AM
Send a message via Skype™ to kendallcschm
-4" stack kit
-3" downpipe
-cat gutted
Thanks
depends on engine condition, and tunes on the TS chip. i'd say 300 at the crank 200 at the wheels on the +140HP tune
Old 12-25-2012, 11:47 AM
Delivers Pizzas For Fun!
^^ not even.. even on a 140hp tune, no more then 80hp can be had if your lucky.
Old 12-25-2012, 11:59 AM
That guy didn't even put down 400.
Old 12-25-2012, 12:15 PM
However this guy put down 475 without spray and 800+ with the NOS.
Old 12-25-2012, 12:59 PM
yea but what mods were they running and a stock 7.3L makes 200CHP or 185CHP.. so 200HP at the wheels with mods seems about right for the mods the OP listed
Old 12-25-2012, 01:02 PM
Is that first truck trevors (bigredstroker)??
Old 12-25-2012, 01:14 PM
Yep sure is. If he put down 400 it was barely.
Old 12-25-2012, 01:16 PM
The first truck was running C code injectors and a D66 if I remember right. Jeff's mods are off the chain.
Old 12-25-2012, 02:56 PM
The MOST you would have is 290 at the crank and 245 at the tires
The MOST you would see from a chip in an OBS(90cc injectors) is 65hp.
Unless it is a Cali truck(120cc injectors) then you would be more likely to see 350 at the crank and 295 at the tires
