what transmission should i go with? - Ford Powerstroke Diesel Forum
Old 12-22-2012, 07:45 PM
I have a 97 f350 cclb 6" lift on 37"s , I got stuck the other night in a massive snow drift after about 24 hours the plow was finally able to get me out drove the truck home let it thaw out and headed to town. I noticed the torque convert wasent locking and when I got to town I smelt burnt transmission fluid I got out and it was leaking fluid out the front of the transmission, put some Lucas in it limped it home and it started pouring fluid out truck has 177, 000 miles all stock for now, I'm looking into aftermarket transmission and don't know what to go with. The truck is my dd but I do plan on a programmer and injectors when the time comes I don't drag race but would like to pull once in awhile. What to do?
Old 12-22-2012, 08:08 PM
Ats has alot of good options depending on ur driving habits how often u tow and what upgrades u have or plan to do. Just my .02
Old 12-23-2012, 02:55 PM
BTS has a life time warranty, not cheap but can you really put a price on that kinda warranty? and john woods is about the exact same out here in so cal, just depends where your at
Old 12-23-2012, 03:37 PM
BTS are one and done builds.
John Woods builds various types, depending on what your needs are.
Old 12-24-2012, 09:24 PM
If a trans like those arent in your budget you could talk to a local trans shop and have them build what you can afford. Another option is to do a manual swap
Sent from my iPhone using AutoGuide.com App
Old 12-24-2012, 10:00 PM
Budget option would be to buy a reman E40D, slap a triple disk converter on it along with a upgraded valve body and drive it until it blows again. If your power levels stay near stock, you should get at least another 177xxx out of it.
If you plan to bump up the power, go with a built unit. BTS is king of the mountain when it comes to transmissions for these trucks. John Woods would be the next bet. There are also BD Diesel, ATS, and RacerX transmissions that have been proven to hold up to some serious power and abuse.
What kind of budget are you on?
